Mike-the-cat
Flight distance : 22488593 ft
Singapore
Altitude Drones Posted at 2017-5-18 23:53
Yes, I've used Spotlight Pro and Active Track to do the job.
Some times they work and others they don't. You need a good track point which can be impossible depending on the subject and even if you do have a good track point it can disappear as you move around the subject. This can cause the camera to search for it's track resulting in juddery footage..
It's strange that the algo isn't implemented for the Inspire 2 since the feature was available for the I1. So I doubt a technical reason is in place here.
The only logical reason I can think for deliberately blocking the feature is that for POI, you have to fly directly over the object of interest and then back off.
Given that the I2 is a much heavier craft, there 'may' be some concern over safety / public nuisance effects.
DJI won't disclose why they don't have this feature and to be honest, admitting to the above, if it were true would draw unwanted attention. I think in the end, it was a risk management call and right now, the risk reward ratio didn't cut it for the manufacturer.
