Phantom gone...R.I.P.
12Next >
3470 54 2017-3-29
Dronebird
I was flying with my Phantom 3 Pro along the shore. In the beginning I could take photos and videos without any problems, but suddenly I received a warning:
Magnetic Field Interference. Exit P-GPS Mode.
The drone rapidly flew away from me (I think ATTI mode), as I couldn't control it, I pressed the Home Button.
The drone flew back and was very close to me from this point I tried to land it, but unfortunately it flew again away from me.
All this actions took a lot of battery power, and drone said:
Critically Low Power. Aircraft Landing.
It initatied this about 200 m in the open sea
R.I.P. Phantom 3 Pro
What did I do wrong, and how I can avoid these issues in the future ?
Thanks !
2017-3-29
FrequentFlyer
Were you near any large metal objects or was there anything between you and the drone?
2017-3-29
blackcrusader
Flight distance : 689774 ft
Taiwan
Perhaps you can upload your flight logs so an assessment can be made by our learned members and DJI staff.
Apart from magnetic interference perhaps you also had high winds as you were near the shore where winds can be quite an issue.
Sorry about your loss.
2017-3-29
Dronebird
There were no large metal objects around,  only a mountain was close by.
I m going to look for my flight logs.
2017-3-29
Mark The Droner
Flight distance : 2917 ft
http://www.phantomhelp.com/LogViewer/Upload/
(thank you msinger)
Sorry for your loss
2017-3-29
DJI-Ken
Flight distance : 1515312 ft
Sync your flight records and I can look at your flight to see if I see anything unusual. Also provide your email used for the DJI account.
It's strange that RTH worked but after it came close to you it went the other direction.
Also, when you get critically low battery you can still fly by keeping the throttle up and you can fly all the way to zero%.
2017-3-29
#shotxclvck
Flight distance : 3423297 ft
This happened to me once with my standard- u must make sure to calibrate and always record home point
2017-3-29
RicardoGray
Flight distance : 4356421 ft
You should of been able to maneuver a little bit after the auto land initiated. I mead I doubt you could have come back from 200m over the water, but you still have some control if you were to push up on the left stick to gain altitude and try. It would have go as far as it could until it went completely out of power. It is strange that it came back and then took off again? Sorry for the loss! Yeah, upload log files and maybe someone can offer some explanation.
2017-3-29
Sp00nix
Flight distance : 28678 ft
Does salt water have any effect on any of the sensors?
2017-3-29
Eric13
Flight distance : 13875118 ft
Sp00nix Posted at 2017-3-29 11:09
If your drone took a bath in salt water you don't need to worry about sensors. The drone will be trash.
Even if you manage to bring it back to life by rinsing with fresh water, having it sit in rice for a few days etc:
Corrosion will kick in and you cannot rely on it anymore.
2017-3-29
capbat
Flight distance : 54905 ft
I would guess 'Yes'.
2017-3-29
Eric13
When I read "shore" it reminds me of my problems with the P3S:
Once on a concrete landing pier I got this "Magnetic Field" warning. Another time in a harbour with concrete surface.
Then again over a concrete scate park.
Have you been near/on concrete? I guess ferro concrete is a problem...
2017-3-29
Dronebird
No, there were just mountains, and far away a big antenna on the mountain peak, maybe that was the reason for problems.
I m going to figure out how to sync and do it. I had to chancel RTH, when it was close to me as I was worried that landing is not precise enough, ground was on the cliffs and not very stable.
2017-3-29
RicardoGray
Dronebird Posted at 2017-3-29 11:46
I doubt it was the large antenna long ways away, but could be wrong. I have flown pretty close to some before, always aware and ready to react if something went haywire, but the only thing I ever experienced was a loss of signal for a bit, but no crazy movements. I understand now that you cancelled the RTH when it got close to you, so it must have somehow triggered another RTH because of the low battery, which for some reason was going to a different home point, and then initiated the auto land for critical low battery.
There were issues with the Standard resetting the home point but I haven't heard of that issue with the PRO. Was all of your firmware etc. up to date?
2017-3-29
Dronebird
RicardoGray Posted at 2017-3-29 12:05
I never made a firmware update.
2017-3-29
RicardoGray
Dronebird Posted at 2017-3-29 12:08
Fair enough. Just trying to help. Sorry man, it is strange for sure. Hope someone can offer some explanation.
2017-3-29
Geebax
Eric13 Posted at 2017-3-29 11:22
'Corrosion will kick in and you cannot rely on it anymore.'
That does not have to be the end. Corrosion will only occur after a lengthy period in the air with salt on the aircraft. If you recover it from salt water, the first thing to do is rinse it thoroughly in fresh water, then place it in distilled ater for a couple of days. Follow that up by blowing the water out, let it dry and then use /dessicant or rice to dry it out. The battery will be ruined, so throw that away.
2017-3-29
Cabansail
Flight distance : 136686 ft
Important thing is not to let the salt water dry as that's when it forms crystals. That is why when they recover an orange Black Box from an aircraft they sela it with the water around it.
2017-3-29
Labroides
Flight distance : 9991457 ft
#shotxclvck Posted at 2017-3-29 09:53
"This happened to me once with my standard- u must make sure to calibrate and always record home point"
These stories usually come from someone that calibrates the compass every flight.
Unnecessary recalibration of a perfectly good compass has the potential to cause problems.
2017-3-29
RedHotPoker
Flight distance : 165105 ft
Sorry to read about this.
RedHotPoker
2017-3-29
AG0N-Gary
Flight distance : 700846 ft
Dronebird Posted at 2017-3-29 08:24
I'm not saying this has anything to do with your loss, but DO be aware that some mountains have magnetic properties.  Airplane flight charts are usually marked with those areas because there is danger of aircraft compass error while in the area.
2017-3-29
Labroides
"What did I do wrong, and how I can avoid these issues in the future ?"
Without flight data you are only going to get people making guesses and most will be wrong or irrelevant.
2017-3-29
DJI-Jamie
Flight distance : 112405 ft
As far as syncing the Go app flight records, you would tap on the cloud icon that's in the Flight Records section of the Go app. It's normally on the top of the page.
2017-3-29
Dronebird
Thanks for your help, really awesome community !
I just uploaded my flight records
2017-3-29
RedHotPoker
Please visit www.phantomhelp.com/LogViewer/Upload then post the link to your last flight log.
RedHotPoker
2017-3-30
T3rdEye
Flight distance : 221844 ft
Geebax Posted at 2017-3-29 14:09
I agree with everything Geebax says except
DON'T EVER USE RICE AS AN ABSORBANT it gets into loads of places , touches moisture then swells so it won't come out without further dismantling especially around the gimbal, motors, etc..
I have heard you can use dried peas??
2017-3-30
Dronebird
This Phantom can't be dried anymore, as it landed in the sea
Gone...
2017-3-30
Sp00nix
I'm hoping this was a sarcastic response.
2017-3-30
Labroides
Dronebird Posted at 2017-3-29 23:50
Unless you post a link to the Phantomhelp.com report, no-one can see it to work out what realy happened.
2017-3-30
Labroides
Sp00nix Posted at 2017-3-30 04:14
??  Sarcastic?
No it's just what happens when an electronic device with a live battery hits salt water.
Probably >99% would be sizzled in a microsecond.
2017-3-30
Sekafetz
IF it was a microwave link AND you flew into the path, there is always a possibility of interference. The coastlines use a lot of microwave links as the fiber lines tend to break when there are landslides - at least here in the PNW.
2017-3-30
greenwire
Flight distance : 38281 ft
Dronebird Posted at 2017-3-30 03:50
Gone...
RIP
Hoping your flight log will uncover some glitch
2017-3-30
Dronebird
Here we go:
http://www.phantomhelp.com/LogViewer/7IFM601QFM6ORXO4OQWQ/
2017-3-30
DJI-Ken
I reviewed the flight but I can not tell what happened, I see the GPS signal kept going in and out. Has it ever been crashed and you've never made any modifications have you?
It's best to start a ticket with support (if you haven't already) and let the flight data analysis team analyze the flight as they can better determine cause.Also you're flying over the ocean but you have your RTH altitude set to 200 meters. But that wouldn't cause any errors, just contribute to battery drain which was 6% as you were 300 meters offshore.
Maybe the default RTH altitude could have let you have enough battery to bring it back in.
2017-3-30
Labroides
Dronebird Posted at 2017-3-30 06:18
Here we go:
Right ... your flight data confirms your story.
It shows the flight starting normally and having no problems until 8:31 when it started showing Yaw errors.
This is a kind of compass error but usually caused by a malfunction.
The Phantom had been out over 800 feet without any error messages before this which suggests that the problem was not caused by a bad calibration or launch point.
The yaw errors continued until 9:59 and returned again at 12:28 (but compass errors this time).
As well as all the yaw error and compass error messages there were a few speed error messages which also hint at a malfunction.
The Phantom was uncontrollable while in the error state and eventually got to 10% and initiated critical low battery autolanding about 60 metres from home point.
It is highly likely that this was all due to a malfunction and not user error.
You should synch your flight record by clicking on the cloud icon in the app where you can see the flight records.
After you have uploaded it to DJI, contact their online support chat and tell them the story and see where they go with it.
Good luck with it.
2017-3-30
Dronebird
DJI-Ken Posted at 2017-3-30 06:47
I didn't do any modifications, but I also never flew it ATTI mode before
@Labroides Thanks for your great analysis !
2017-3-30
DJI-Ken
Dronebird Posted at 2017-3-30 07:25
OK, no crashes either right?
The Flight Analysis department will figure it out.
2017-3-30
Dronebird
DJI-Ken Posted at 2017-3-30 07:56
And no crashes
Thanks!
2017-3-30
DJI-Ken
Ok, good.
Thanks
2017-3-30
RedHotPoker
Here we go:
Thanks... That can be a helpful aid...
RedHotPoker
2017-3-30
12Next >
