Still no battery recognision in Airdata app?
977 10 2017-3-29
NavigatorNL
Flight distance : 700768 ft
Used to be a problem in 'Airdata' (Healthydrones) with Mavic batteries. I have three batteries, Airdata only recognise 1 (showing no serial nrs. at all), or shows all the data from three on the data of one battery.
Anyone recognise this problem?
2017-3-29
SkunkWerxs
Flight distance : 231217 ft
Does the battery Data come up after flying your Mavic ?
2017-3-29
NavigatorNL
It does on DJI app. Not able to export to Airdata.
2017-3-29
laceyboy
Flight distance : 159820 ft
Was just wondering if you are paid Airdata member?
2017-3-29
NavigatorNL
Yes, gold member.
2017-3-29
Jenee 2
Flight distance : 7852129 ft
According to Airdata it is an issue with ios not storing the battery data. They say that DJI needs to fix this. It does work fine with android.
I manually update the battery info in Airdata after I upload my flights.
2017-3-29
NavigatorNL
Thanks. I will do the manual trick too.
2017-3-30
mstevens
Flight distance : 19078 ft
NavigatorNL Posted at 2017-3-29 11:18
It looks as if this is in response to "Does the battery Data come up after flying your Mavic?"
Are you saying that there is some way within the logs in DJI Go 4 to see which battery was used on which flight?
2017-3-30
Jenee 2
mstevens Posted at 2017-3-30 13:33
No I don't think so. I have written my serial numbers on each battery and just take note of which ones are used for each flight. You can also see the serial number in the DJO GO app when everything is connected.
2017-3-30
fans6c33d784
Flight distance : 702766 ft
Belgium
This is still the case with iOS GO 4 (version 4.0.7) as of now...  :-(
I wonder why DJI does not fix that?
Anybody?
2017-5-7
NavigatorNL
I moved over to Android / Samsung. Problem solved.
2017-5-10
