After finally getting the firmware to install there is still no option to record RAW/DNG video. In the settings where you select mov or mp4 that's where it would be correct? Does anyone have a solution to this problem?
When you insert SSD card and begin to take video, the compressed footage will be saved in Micro SD card while the raw footage will be recorded in SSD card at the same time and no need to select any format.
