hallmark007
Flight distance : 9827923 ft
You should first sync your flight record in the app to dji cloud,
You can then play back your flight in the app right at the end of your flight, at the bottom of screen just over the slide bar you will see numbers, these are gps coordinates and should mark the last spot your AC was in the sky, you said it dropped straight down so this should help you find your location.
Also if you want others here on the forum to help out you can upload your logs to http://www.phantomhelp.com/Phantom-4/#DataLog.
Hopefully you will find it, did you have dji care or care refresh. |
