coming from a phantom advanced the rule was DONT fly multiple times on the same battery. IE run the battery down then charge to 100% then fly again.the mavic has 27 mins, i might want to have 5 mins at one spot then land and fly again latter on in the day on the same battery.
is this ok with the mavic. ?
I've never had a problem with multiple flights on 1 battery. After all, instances when you want to change your ND filter, or, as you say, move to a different spot are normal.
Airobotix Posted at 2017-3-30 00:58
