Gimbal jsut swings up and down?
681 2 2017-3-30
MrPinaColada
Flight distance : 790082 ft
So I had to remove some sand from my motors which required me to take apart my phantom. I put all the wires back in place, I get no errors etc, but whenever I startup my phantom the gimbal just swings up and down forever. Like it's trying to calibrate but cannot. I tried manually tilting the camera through the gimbal wheel, I tried restarting the drone multiple times, I tried calibrating the camera through the app but nothing gets it to stop tilting all the way up and all the way down. This has happened before and what I usually do is just power cycle the phantom but nothing still has seemed to work.
Edit: Just lightly touching the gimbal while it was tilting up and down got it back to normal. I was testing to see how much resistance there was and there was little no resistance for a second and then it snapped back to how it should be functioning. Weird but im not complaining.
2017-3-30
Maxxgold
Flight distance : 19157 ft
Do a search and you will find all the info you need on this subject.
2017-3-30
DJI-Jamie
Flight distance : 112405 ft
You would want to double check the physical connections, especially the ribbon cable, to ensure that they are secure and inserted in the proper directions?
2017-3-30
