fanscfa43378
Flight distance : 69734 ft
Hi all,
I bought the Handle Kit and the X5 adapter to use my X5 gimbal on Osmo.
I read I need to update FW to make the handle work with X5.
But when I switch it on with OSMO_FC550_FW_V01.03.00.40.bin on the micro SD, I get a few green flashes then the LED switches off.
I can connect to "Camera" in DjiGo app. Then I can see that the firmware is 1.2.0.12.
--> I read on some posts that the last Osmo Pro FW should be done from.. a X5 only.
--> I read somewhere else that I need an X3 camera to update the handle, and then the FW update will work on X5.
I don't have an X3, I think my only solution is to ask to the shop to make FW update?
If you have advice..
