Mark The Droner
Flight distance : 2917 ft
I assume you are telling us the cable broke at the point with the red circle.
My understanding is that two of those antennas are for control and two are for FPV. The two for control would be receiving antennas. The two for FPV would be bi-directional, that is, transmitting and receiving antennas. I don't know which are which though. If we assume your broken cable is for the antenna that is bi-directional, there is somewhat of a risk of burning out the FPV transmitter. The RF energy will move down the cable, and since there is no antenna, it will behave as if the cable is the antenna. The problem is the cable won't be the correct length for a 2.4 ghz wave, so the RF energy won't leave the cable efficiently. Some of it will emit from the cable, and the rest will go back up the cable to the transmitter which would cause it to heat up. If it gets hot enough, it could burn out. Or it might not.
If it's a receiving antenna, it won't hurt anything other than you'll have a seemingly weaker control signal.
MHO |
