Mad_Angler1
Flight distance : 2741657 ft
Gallacherboy Posted at 2017-4-5 09:02
I did not know of that, what tab do you look under? When you open Assistant it only gives you Mavic Pro, how do you select Battery Update???? Thanks for the heads up
The firmware is stored on the craft you do not update the batteries via Assistant 2
Update your craft to the latest fw then turn it on with each battery in, the Go app will prompt you to update of the battery needs to be updated.
