MadFrenchie
Flight distance : 914711 ft
Mike-the-cat Posted at 2017-4-2 20:13
No idea but suggest you do a few further test flights with the aircraft on a short leash to see if the problem is replicated. I don't know how you managed to pull out one battery only as pressing the button usually ejects both. Also, what were you thinking when you swapped out only one battery with the craft still on (testing battery redundancy with cells already low?)
My guess is that the operating system did not load up properly after the atypical shut down procedure. Normally, this should clear after a system check at the second boot up but rarely, you might have corrupted parameters somewhere.
The button is broken down into an Inner and Outer button allowing you to remove only one battery at a time. It was designed this way for a reason.
I have been preforming this since Day1 before / after the firmware update without any issues.
I do a lot of live streaming with the drone, therefore leaving it on is essential to maintaining a good feed. (People prefer to look at Feet and stay connected, but as soon as you stop sending video, they all log off the feed thinking its done)
If you do it properly, and remove the batteries in the correct order, Inner button first, Outer Button Second, then you won't have any issues at all.
There are many other good reasons to swap batteries this way, Faster Turn Around being one of them, and taking off from a boat being another important one. I usually boot up on land, and then bring the drone on the boat, when i land and do a battery swap I don't have to shut down the unit and re initialize the IMU. |
