app forgets my camera settings
1178 11 2017-4-2
patman89
Flight distance : 288327 ft
Hi,
finally I got my Mavic Pro! But there is one thing which is bothering me. The DJI GO App always forgets my camera settings, especially the file format (JPG+RAW). Am I doing something wrong?
Best regards,
patman89
2017-4-2
4wd
Flight distance : 545817 ft
Are you connected to the Mavic while changing?
Most settings are actually stored in the Mavic and the app can change them - but it doesn't store anything.If using alternate devices this is quite noticeale.
2017-4-3
CuaC
Flight distance : 369626 ft
I've had this happening to me a couple of times! I was going mad, glad to know I'm not the only one! It's specially annoying exactly with the R+J option, which is the only important thing for pictures to me!
2017-4-3
patman89
I think this happens if you change the control mode.  While Active Track is choosen, you don't have the option to change the file format. Maybe this is why it is reset to JPG all the time.
@4wd yes I am connected to my mavic. I change this parameter everytime I have taken a couple of pictures until I realize they are only stored in JPG. Really anoying...
@DJI maybe this is worth a feature request for further app development?
2017-4-3
4wd
If you use some of the special modes it will switch to JPG, could that explain it?
2017-4-3
patman89
4wd Posted at 2017-4-3 00:48
Yes this is what I think. Maybe this could be fixed easily :-)
Btw. how do I get my flight-distance shown under my avatar?
2017-4-3
4wd
patman89 Posted at 2017-4-3 04:37
I've no idea it just appeared, I think it could be feet or metres not miles or Km!
They also know I have Mavic and P3P, it's a bit cheeky telling everyone that without me saying OK.
2017-4-3
patman89
Okay, maybe I haven't traveled far enough yet :-P But I agree. They show your stats without asking.
2017-4-4
patman89
patman89 Posted at 2017-4-4 01:59
My flight distance didn't show, because I never snyc'ed my flight-records. Problem solved ;-)
About the picture format changes: This happens if you change the flight-mode to any intelligent-mode! It seems you can not shoot in RAW/DNG while using activ-track, tapfly and so on. In my opinion this should be fixed - at least when you return to normal "controller-mode" it should get the settings I have choosen before (JPG+RAW).
2017-5-2
patman89
As far as we know, the camera settings revert to "JPEG" if you enter active track. But that is not the only setting which changes! I noticed that the video setting has changed to 4K/30fps too. Even if you have selected PAL, which allows only 4K/25fps.
It would be great if DJI can take a look into this and fix the app that it don't change the camera settings. It's very anoying to adjust it everytime you select an alternative flight mode.
2017-5-16
Speleo-flyer
patman89 Posted at 2017-5-16 04:38
It also seems to change the white balance and/or compression settings, too, and also the image size (from 4000x2250 to 3840x2160, in 16:9 ratio).  :-(
2017-6-7
patman89
It seems this problem has been solved with DJI GO 4.1.0 :-)
2017-8-28
