Spot for a Inspire 2 plate
644 6 2017-4-3
skypal
Flight distance : 560256 ft
According to the new german drone regulation a UAV above 2 Kg must have a fire proved plate with the pilots information.
These plates are made by aluminium.
So I like to have someone from dji to take a look on the spot I chose and tell us whether that might interfere with the operation in some kind with signals or sensors.
Thanks.
2017-4-3
skypal
Thanks.
Plate
Plate
2017-4-3
MadFrenchie
Flight distance : 914711 ft
That's a nice place, and seems like a good location, the only problem I see is that is one of the more likely places (Other then the ESC's) that will catch fire first.
As far as interference, it shouldn't be an issue.
2017-4-3
DJI-Jamie
Flight distance : 112405 ft
skypal Posted at 2017-4-3 02:34
Is that attached via some sort of adjesive or something else? It's a little hard to tell.
2017-4-3
skypal
DJI-Jamie Posted at 2017-4-3 14:57
Yes its a M3 adhesive pad
2017-4-3
DJI-Jamie
skypal Posted at 2017-4-3 15:47
If you're not blocking any vents and the piece is light, then it could be ok. If you're not using a GPS tracker on your unit, you could also put the plate on the back of the battery compartment so it ensures even balance.
2017-4-3
skypal
The weight of the plate is no more than 0,05 Ounce
2017-4-4
