Donnie *
Flight distance : 3636782 ft
Make sure you are choosing the X5 camera option from the drop down list ( Look at example ) if you own the Inspire pro , I am assuming you do becasue this is a common problem . Be sure to select the camera system from the "Product Select " drop down list , then it will bring you to the downloads page you want .
If you own the X3 Inspire it will default to that Firmware , IF THIS IS THE CASE then read my tips page for more possible ideas to solve your issue. Usually it boils downt to the wrong FW or the SD card is not formatted correctly and or you are using a MAC for the download , Use a PC if you are having troubles, ( If you have a MAC ).
****NOTE : Not all MAC users have issues , I own a MAC and love it, BUT some members do have FW issues and loading via the PC solves the issue for whatever reason ..... I dont make the rules I just figure out ways around them.
Make sure you update the Aircraft first then the RC and DO NOT do them at the same time ( If you need to upgrade both , depending on where you are currently at on the FW on the AC and RC )
http://forum.dji.com/thread-72851-1-1.html
donnie
