Ex Machina
Flight distance : 1806362 ft
Sorry to hear this!
The problem when you lose radio telemetry is you have to guess, since your data is incomplete. You state your Remote Controller Signal Loss setting was set at RTH, but if it was instead at Hover or Landing then you have to figure out how far it would have continued on course in Sports Mode in the two seconds or so that it takes to trigger this feature, and focus your searching in that area.
Where was the sun? Would the Mavic have had to fly towards the sun on a RTH course? If so, you may have run into the dreaded scenario where the Sun triggers object avoidance, and so you then have to consider what the Mavic's response is configured for -- if RTH Obstacle Check is enabled, then the Mavic will rise when OA kicks in, trying to overcome the height of the obstacle, which, of course, isn't going to happen with the Sun. At some point the battery drain will force the Mavic to land, but where OA activates may be hard to guess if the sun was low in the sky and partially hidden by trees and buildings.
Good luck, and hope you find it.
