RicardoGray
Flight distance : 4356421 ft
Blackbeagle Posted at 2017-4-4 05:12
I was not in a fly zone. I've gone to my local park, a playground, and the racetrack (which is closed for the season). None of them are considered no fly zones. I'm just getting the message, "Disconnected" on top, no camera view and isn't able to calibrate (press OK and nothing). However, like I said, I can still start up the P3A and fly. I just don't want to do it when I can't see anything on the tablet (Samsung Galaxy Tab A). By the way, I use Litchi. I also have Go App installed, but that doesn't work either.
Remember, you don't have to have your RC to fly your phantom, but yes it is the best way. Your controller is obviously connected. uninstall the app and re-install to see if it helps. Are you turning on the RC (with tablet, device not connected...app can be running but do not hook up cable yet), then power up the drone, now plug your cable in. This is the correct procedure and may make a difference for you. If that doesn't work and you are able to get into the app, but no video present, try to toggle the RC on and off again. Best of luck |
