Problem could not shut off motors
716 8 2017-4-4
fansed5d1cc0
Flight distance : 325659 ft
I was flying from a boat the other day, someone would hold the P4 Pro by the landing gear for takeoff and catch it by the landing gear to land.  With my old P3 Pro I could just shut off the motors using the controls when someone was holding the drone like this.
With the P4 Pro I could not get it to shut off its motors at all.  It would not respond to holding the joysticks down and in to shut off the motor, as if it thought it was in danger or something.  A person was holding it by the landing gear.
How can I get the Quadcopter to shut down the motors once it is being held on a boat by the landing gear at sea?  I would up having to have the guy hold it down on the deck and it took many tries and prompt overriddes to get it to finally agree to "land" even though it was being held all the time by the landing gear
-Roger Uzun
2017-4-4
Mobilcams
Flight distance : 2907674 ft
On a boat you are drifting around.. The Phantom thinks it needs to correct for these movements and will wind up the motors to do so. The CSC will NOT kill the motors because the combination is different for the P4P.  Next time try to put it in ATTI mode once it is caught then try to shut down the motors, or try to shut down the motors using the P4P (and P4) motor shut off combination.. That is accomplished by holding the left stick down and towards the middle and pushing the RTH button - make sure your partner has a good grip on it at this point because the motors will shut off.
2017-4-4
droningaroundth
Flight distance : 7344777 ft
The same happened to my P4P on a boat and I was alternating with a friend who would hold the Drone by the landing gear until I got the combination of buttons right (including the RTH)...
2018-1-20
Tom Saavedra
Flight distance : 38415 ft
droningaroundth Posted at 2018-1-20 08:12
Sticks down and in is to start motors.
Hold only the up & down stick all the way down to shut them off on a P4P.
If you land then hold the sticks down and in, that should result in not so good ground movement.
Please, for the safety of everybody around you, familiarize yourself with the craft & controls.
2018-1-20
sky wombat
Flight distance : 1454078 ft
OK so the original post goes back to April 2017, but be nice to know outcome. I'm a bit confused here (not an unusual state). So could switch off the motors when hand catching the  P3 so obviously knew how it worked. But was the issue about not being able to switch off the motors when you are on a boat or can't switch off period?
Mine works as per Tom's advice (4#).
Just curious.
2018-1-20
KedDK
Flight distance : 1133038 ft
Denmark
Tom Saavedra Posted at 2018-1-20 13:47
The problem is, if the boat moves the AC detect movement and don't know it is safe to turn off the motors. Emergency stop might be needed, Left stick down and in + RTH button.
2018-1-20
sky wombat
KedDK Posted at 2018-1-20 16:25
Thanks Ken got it now.
2018-1-20
Tom Saavedra
Ahhhh, I see.
2018-1-20
Bashy
Flight distance : 2354357 ft
This happened to me once, i ended up telling it to land in the app (whilst holding it) and that worked fine
2018-1-20
