DJI GO (V3.1.7) for iOS is Available
12
10250 79 2017-4-4
Kd7gx
Flight distance : 82700 ft
In order to get this to work on an iphone 7 I have to start controller, aircraft,(phantom standard) put phone in airplane mode, start phantom wifi, if not in this order the app just crashes for me.
2017-4-5
DJI-Ken
Flight distance : 1515312 ft
For now please turn on Airplane mode and the app will run.
2017-4-5
JmIsenberg86
Flight distance : 2454 ft
Nikon 1 Posted at 2017-4-4 04:00
Hopefully nothing existing was broken.  Will this update signal new F/W for the Mavic Pro?
I use the DJI go4 app for the mavic(as suggested per DJI) and it does notify you that there are FW updates
2017-4-5
carlfacer
Flight distance : 1612680 ft
Wait, DJI-Ken, how will this help us users of the Phantom 3 Standard that NEED Wifi to connect to the controller? I am supposed to be flying this afternoon and because of the app crashes I am unable to! Unacceptable!
What is the ETA on a resolution for this?
2017-4-5
flyboymd
Flight distance : 154498 ft
I just spoke with support on this. They say it only affects ios devices at this time and a fix will be out in 24-48 hours. In the meantime as many have stated in the forum (I have not tried this yet however) you should be able to turn on airplane mode, start App, then turn airplane mode off and everything should work as usual. Crossing fingers!
2017-4-5
Benny Davidovic
Israel
spartan67 Posted at 2017-4-5 06:41
Problem solved, I prohibition in the phone to DJIGO mobile  data, connect to the osmo via wifi and applications work.Nice day.
It is not working!
2017-4-5
Xlear99
flyboymd Posted at 2017-4-5 07:59
Do I have to do this workaround every time I launch the app?
2017-4-5
fans62fb8d14
Flight distance : 331391 ft
Malaysia
yeah quite troublesome ... are the update significantly better ?
2017-4-5
NicoNic
Can´t Set my EV Settings via dial  ... just today ... has it anything to do with the new update ?
2017-4-5
fans27b73483
Flight distance : 491808 ft
All - the process of go into Airplane mode, turn the app' on, then turn wifi on, connect, then get into the app and connect to the device (Osmo+) and then turn on cell' does work!...
P
2017-4-5
AIRFLIX.dk
Flight distance : 8077667 ft
Denmark
This company is starting to look less and less professional. How on earth can they have so many issues in one app.
2017-4-5
fans589cba4b
Flight distance : 12780633 ft
App not working.
2017-4-5
andre.staehli.b
Flight distance : 4313343 ft
Switzerland
Same here, both on iPhone and iPad
2017-4-5
DJI-Ken
carlfacer Posted at 2017-4-5 07:55
Leave Airplane mode as is and turn off cellular and it will work.I just verified on my Standard and it's fine. Also, when I turned cellular back on the app is no longer crashing.
2017-4-5
remius
Flight distance : 382405 ft
Belgium
Ok. Thanks for the tip DJI-Ken, it worked fine for me.
Please, post here when update is available.
2017-4-5
Powerguy50
Flight distance : 1234 ft
Kd7gx Posted at 2017-4-5 07:27
And don't forget to stand on your left foot only, facing north, and rubbing your head in a clockwise motion...
2017-4-5
spartan67
Czechia
Iphone 6plus settings, applications, djiGO, mobile data, turn off,  connect Dji osmo via wifi, for me it works perfectly.
2017-4-5
DemolitionMan14
Flight distance : 1963583 ft
Who even uses an editor on a portable device?  Any professional will wait to do editing until they are in front of a computer and either use FCPX or Adobe Premiere.  If you want to update an APP update GS Pro so you can log in and have it record your flight logs like DJI GO does.
2017-4-5
Gateway
Flight distance : 1873806 ft
Confused.. isnt DJI GO for older drones, not Mavic, I2, etc? Not sure why this was posted here?
2017-4-5
Eric13
Flight distance : 13982031 ft
Looking at the improvements as described by DJI is somehow like this:
You have multiple issues with you car and take it to the repair shop.
When you pick it up nothing was fixed but they smile at you saying:
We've painted it with the latest color!
2017-4-5
Cabansail
Flight distance : 136686 ft
Mine seems to work straight out of the box. So It's not all iOS devices.
2017-4-5
Shirkan
Shuts down the iPhone and -or- iPad
2017-4-5
Alex2017
Flight distance : 27428 ft
How do I scan the qr, the app pull down menu doesn't have that function. Asked but no one answered!!!
2017-4-6
RAMJET-1
Flight distance : 2180843 ft
MikeQView Posted at 2017-4-4 07:12
i would like it just to work !     i currently have an Android phone and tablet,  both are not great!  and very frustrating as some things that work yesterday dont always work today? its certainly not repeatedly reliable.  so i am biting the bullet and buying an Ipad mini 4 cellular so i can dedicate it to the mavic,   just so that i can try each option before i throw in the towel.
Let us know the results. From all I've read it's not working with Iphones??
2017-4-6
RAMJET-1
Gateway Posted at 2017-4-5 13:17
WELL PUT!!!  I was thinking the same thing. Posted updates that don't apply to Mavic Pro for ISO and Android. WTH are they doing!!!!!  I mean look, due to the latest Go4 update not working (crash, crash, crash) on Android, I was forced to downgrade to the old DJI Go 3pp 3.1.3 version which no longer SUPPORTS Mavic or P4P.... BUT it works flawlessly!! Just had to vent a little.
2017-4-6
Saxzter
Flight distance : 252726 ft
Norway
Probably a stupid novice question, but why is this posted in the Mavic-forum? I thought we had to use the DJI Go 4-app, which is currently in v4.0.6 (2855).
2017-4-6
EJay
Flight distance : 541818 ft
Not sure why this notice is on the Mavic area when I thought DJI 4 Go was recommended for Mavic. Probably something simple I don't understand?
2017-4-6
fansf4d6385e
Switzerland
La emisora no se conecta con la aplicación
2017-4-6
Xlear99
Could you tell me what is the Curved Mode in the edit tool in the app?
2017-4-6
fans751360fa
Random question... why does the DJI GO APP need permission to make calls...?
2017-4-6
MD_Icarus
I am back after a long winter, and I see the same issues I remember when I went into winter hybernation.
I wish there is a mode to disable the DGI GO asking me to update.  I am afraid I may click on it by mistake.
2017-4-6
trickn0l0gy
Flight distance : 156040 ft
Switzerland
Hi there,
since this update, I cannot use my Apple battery case anymore, because the app does not recognise the connection to the RC anymore. It worked very well before, why did you turn off the compatibility.
Just for clarity, I am speaking of this:  http://www.apple.com/ch-de/shop/ ... %E2%80%93-anthrazit
As long as this is slipped on the phone and the connection is made through it, the DJI GO app will not recognise the RC. Weird! Please fix this. Thank you.
2017-4-7
Mike-the-cat
Flight distance : 22488593 ft
Singapore
The problem was due to something on the server end. As of April 6th or so it has been fixed.
2017-4-7
RSanJuan
Flight distance : 2188 ft
So is this issue actually fixed now, and if so, is the fixed version of DJI GO still v3.1.7 or is it different?  In other words, how would one know if they have the fixed version loaded?
2017-4-8
MikeQView
WTF !  this is abismal for a program that flies  £1000 to £12,000 aircraft,   Come on DJI this is just pathetic,  even if people are finding work arounds by switching things off,   is that why we all paid good money for these ???    The OP was dead right,  that when the CAA's start seeing that the controlling App is so poorly written and executed,  i wouldnt be at all surprised to see them banned soon.  its ironic that the old APM and Naze32 derivatives still knock the spots of these craft for flight reliability,  and its why i am going back to these flight controllers, and building my own craft all over again,  i have just about had enough of this,  its such a shame that DJI want to bury their heads in the sand,   and its for that reason why they have become a second rate company.   it doesnt matter a jot if your latest craft has 50 really clever features or even 60 or more, if it wont fly that still ends up being zero features,  why is it so hard for this company to realise this,   i do notice that not even the DJI mods want to comment or maybe they are not allowed !
2017-4-8
mixchief
Flight distance : 182057 ft
waited till this evening to update iPad as the iPhone six displayed the same behavior as everyone else, iPad so far not connected to remote or Osmo working, iPhone yesterday after update crashes maybe 4 times and then started working ok with Osmo, I will be doing a Facebook live from the AC tomorrow evening so I can't possibly be in Airplane mode, Keeping my fingers crossed, will probably do a few dry runs before putting the AC in the air
2017-4-8
sparrowhawk360
Flight distance : 52090 ft
Thanks for the updates DJI - keep them coming. And please look at 3rd party Apps like Litchi for how we want to use flight planning etc
2017-4-9
MikeQView
Can anyone say if   v 7   is ok ?  does it still keep crashing ?
2017-4-9
amazingfriend
Great, I'll try it.
2017-4-9
Strabun
If I fly with my IPhone 5S, is there a way to transfer my videos to my iPad for easier editing through the DJI GO App?
2017-4-15
12
