Yovandra
When recording video my DJI Osmo got turned off because the battery was run out empty. After that I replace the battery with the fresh one that has still 100% but it doesn't want to turn on, I also tried with other 2 batteries. The power led only turn red and blinking several time and then it stay red after that.
I tried to reset it using the combination key or button, but it doesn't result in anything and still got the same error.
I also tried to update the firmware and it's always failed at 95%.
Here's the log when doing the firmware update:
========== 2014.01.01 00:00:04 remo-con disconnect======
Packet: OSMO_FW_V01.00.00.24.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:03 remo-con disconnect======
Packet: OSMO_FW_V01.00.01.03.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:08 remo-con disconnect======
Packet: OSMO_FW_V01.00.01.19.bin
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:11 remo-con disconnect======
Upgrading ...
Result: Success.
========== 2014.01.01 00:00:09 remo-con disconnect======
Packet: OSMO_FW_V01.02.01.60.bin
Upgrading ...
Result: Success.
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2014.01.01 00:00:10 remo-con disconnect======
Packet: OSMO_FW_V01.05.02.00.bin
Upgrading ...
Result: Success.
========== 2016.04.23 20:03:19 =====================
Packet: OSMO_FW_V99.99.99.99.bin
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2016.10.14 09:28:44 =====================
Upgrading ...
========== 2017.04.04 20:08:45 =====================
Upgrading ...
Packet: OSMO_FW_V01.08.02.40.bin
========== 2014.01.01 00:00:06 remo-con disconnect======
Upgrading ...
========== 2017.04.04 20:45:43 =====================
Upgrading ...
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: OSMO_FW_V01.04.01.80.bin
Result: Abort.
The current firmware does not support downgrade. Use a different version of firmware to downgrade the target version.
========== 2014.01.01 00:00:12 remo-con disconnect======
Upgrading ...
Other more detailed log on hidden folder:
[00004775]========== remo-con disconnect. boot(15) ============
[00004887]Packet [C:\OSMO_FW_V01.00.00.24.bin] detected, card sn [0x90ce3285].
[00004918]Packet upgrade start...
[00004954]Packet checking...
[00004994]Packet vlink 01.00.0024 <-> 01.00.0023.
[00005057]Done.
[00005094]Version checking[1]...
[00007650][07 00][00] v1.0.9.14 -> v1.0.9.14
[00007689][08 00][00] v1.14.0.25 -> v2.14.9.17 need upgrade.
[00007722][01 00][00] v2.17.3825 -> v2.18.3831 need upgrade
[00007754][01 01][00] v2.17.3825 -> v2.18.3831 need upgrade
[00007790][04 00][00] v1.26.0.48 -> v1.26.0.48
[00007823]Done.
[00009856]Waiting for user confirm...
[00019891]Timeout, start upgrade automatically.
[00019959]Firmware upgrading[1]...
[00033806][01 00] Firmware upgrade start...
[00004232][01 00] Firmware upgrade finished successfully.
[00004272]Done.
[00004302]Packet [C:\OSMO_FW_V01.00.00.24.bin] resumed, card sn [0x90ce3285].
[00004341]Packet vlink 01.00.0024 <-> 01.00.0023.
[00004409]Version checking[2]...
[00004497][07 00][00] v1.0.9.14 -> v1.0.9.14
[00004535][08 00][00] v1.14.0.25 -> v2.14.9.17 need upgrade.
[00004573][01 00][05] v2.18.3831 -> v2.18.3831
[00004605][01 01][00] v2.17.3825 -> v2.18.3831 need upgrade
[00004652][04 00][00] v1.26.0.48 -> v1.26.0.48
[00004689]Done.
[00004718]Firmware upgrading[2]...
[00004876][01 01] Firmware upgrade start...
[00035272][01 01] Firmware upgrade finished successfully.
[00036687][08 00] Firmware upgrade start...
[00562331][08 00] Firmware upgrade finished successfully.
[00562363]Done.
[00562394]Version checking[3]...
[00562623][07 00][00] v1.0.9.14 -> v1.0.9.14
[00562668][08 00][05] v2.14.9.17 -> v2.14.9.17
[00562697][01 00][05] v2.18.3831 -> v2.18.3831
[00562729][01 01][05] v2.18.3831 -> v2.18.3831
[00562766][04 00][00] v1.26.0.48 -> v1.26.0.48
[00562800]Packet upgrade finish successfully.
[00004631]========== remo-con disconnect. boot(15) ============
[00004662]Packet [C:\OSMO_FW_V01.00.01.03.bin] detected, card sn [0x60ce2d00].
[00004786]Packet upgrade start...
[00004824]Packet checking...
[00004860]Packet vlink 01.00.0103 <-> 01.00.0102.
[00004898]Record vlink 01.00.0024 <-> 01.00.0023 (flow = 0).
[00004932]Done.
[00004965]Version checking[1]...
[00007524][07 00][00] v1.0.9.14 -> v1.0.9.22 need upgrade.
[00007593][08 00][00] v2.14.9.17 -> v2.14.9.17
[00007633][01 00][00] v2.18.3831 -> v2.23.3994 need upgrade
[00007665][01 01][00] v2.17.3825 -> v2.23.3994 need upgrade
[00007704][04 00][00] v1.26.0.50 -> v1.26.0.54 need upgrade.
[00007754][09 00][00] v0.0.0.20 -> v0.0.0.41 need upgrade.
[00007787]Done.
[00009818]Waiting for user confirm...
[00019851]Timeout, start upgrade automatically.
[00019917]Firmware upgrading[1]...
[00033959][01 00] Firmware upgrade start...
[00018237][01 00] Firmware upgrade finished successfully.
[00018322]Done.
[00018357]Packet [C:\OSMO_FW_V01.00.01.03.bin] resumed, card sn [0x60ce2d00].
[00021444]Packet vlink 01.00.0103 <-> 01.00.0102.
[00021485]Record vlink 01.00.0024 <-> 01.00.0023 (flow = 0).
[00021515]Version checking[2]...
[00021613][07 00][00] v1.0.9.14 -> v1.0.9.22 need upgrade.
[00021669][08 00][00] v2.14.9.17 -> v2.14.9.17
[00021703][01 00][05] v2.23.3994 -> v2.23.3994
[00021735][01 01][00] v2.17.3825 -> v2.23.3994 need upgrade
[00021775][04 00][00] v1.26.0.50 -> v1.26.0.54 need upgrade.
[00021853][09 00][00] v0.0.0.20 -> v0.0.0.41 need upgrade.
[00021885]Done.
[00021914]Firmware upgrading[2]...
[00022062][01 01] Firmware upgrade start...
[00052330][01 01] Firmware upgrade finished successfully.
[00053365][07 00] Firmware upgrade start...
[00155242][07 00] Firmware upgrade finished successfully.
[00155335][09 00] Firmware upgrade start...
[00217762][09 00] Firmware upgrade finished successfully.
[00217855][04 00] Firmware upgrade start...
[00296883][04 00] Firmware upgrade finished successfully.
[00296917]Done.
[00296950]Version checking[3]...
[00297032][07 00][05] v1.0.9.22 -> v1.0.9.22
[00297149][08 00][00] v2.14.9.17 -> v2.14.9.17
[00297185][01 00][05] v2.23.3994 -> v2.23.3994
[00297219][01 01][05] v2.23.3994 -> v2.23.3994
[00297292][04 00][05] v1.26.0.54 -> v1.26.0.54
[00297342][09 00][05] v0.0.0.41 -> v0.0.0.41
[00297375]Packet upgrade finish successfully.
[00008553]========== remo-con disconnect. boot(15) ============
[00008588]Packet [C:\OSMO_FW_V01.00.01.19.bin] detected, card sn [0x70ce5367].
[00008622]Packet upgrade start...
[00009236]Packet checking...
[00009290]Packet vlink 01.00.0119 <-> 01.00.0118.
[00009326]Record vlink 01.00.0103 <-> 01.00.0102 (flow = 0).
[00009379]Done.
[00009412]Version checking[1]...
[00009467][07 00][00] v1.0.9.22 -> v1.0.9.22
[00009516][08 00][00] v2.14.9.17 -> v2.14.9.26 need upgrade.
[00009551][01 00][00] v2.23.3994 -> v2.29.4149 need upgrade
[00009586][01 01][00] v2.23.3994 -> v2.29.4149 need upgrade
[00009633][04 00][00] v1.26.0.54 -> v1.29.0.0 need upgrade.
[00009673][09 00][00] v0.0.0.0 -> v0.0.0.62 need upgrade.
[00009708]Done.
[00011743]Waiting for user confirm...
[00021777]Timeout, start upgrade automatically.
[00021847]Firmware upgrading[1]...
[00036687][01 00] Firmware upgrade start...
[00022156][01 00] Firmware upgrade finished successfully.
[00022188]Done.
[00022222]Packet [C:\OSMO_FW_V01.00.01.19.bin] resumed, card sn [0x70ce5367].
[00022266]Packet vlink 01.00.0119 <-> 01.00.0118.
[00022302]Record vlink 01.00.0103 <-> 01.00.0102 (flow = 0).
[00022336]Version checking[2]...
[00022406][07 00][00] v1.0.9.22 -> v1.0.9.22
[00022452][08 00][00] v2.14.9.17 -> v2.14.9.26 need upgrade.
[00022486][01 00][05] v2.29.4149 -> v2.29.4149
[00022520][01 01][00] v2.23.3994 -> v2.29.4149 need upgrade
[00022592][04 00][00] v1.26.0.54 -> v1.29.0.0 need upgrade.
[00022631][09 00][00] v0.0.0.0 -> v0.0.0.62 need upgrade.
[00022664]Done.
[00022695]Firmware upgrading[2]...
[00022787][01 01] Firmware upgrade start...
[00053055][01 01] Firmware upgrade finished successfully.
[00053786][08 00] Firmware upgrade start...
[00580633][08 00] Firmware upgrade finished successfully.
[00580696][09 00] Firmware upgrade start...
[00645833][09 00] Firmware upgrade finished successfully.
[00645904][04 00] Firmware upgrade start...
[00727420][04 00] Firmware upgrade finished successfully.
[00727459]Done.
[00727494]Version checking[3]...
[00727545][07 00][00] v1.0.9.22 -> v1.0.9.22
[00727677][08 00][05] v2.14.9.26 -> v2.14.9.26
[00727710][01 00][05] v2.29.4149 -> v2.29.4149
[00727746][01 01][05] v2.29.4149 -> v2.29.4149
[00727789][04 00][05] v1.29.0.0 -> v1.29.0.0
[00727836][09 00][05] v0.0.0.62 -> v0.0.0.62
[00727869]Packet upgrade finish successfully.
[00010483]========== remo-con disconnect. boot(15) ============
[00010515]Packet [C:\OSMO_FW_V01.00.01.19.bin] detected, card sn [0x40ce4faa].
[00010549]Packet upgrade start...
[00010586]Packet checking...
[00010632]Packet vlink 01.00.0119 <-> 01.00.0118.
[00010666]Record vlink 01.00.0119 <-> 01.00.0118 (flow = 0).
[00010702]Done.
[00010733]Version checking[1]...
[00010794][07 00][00] v1.0.9.22 -> v1.0.9.22
[00023332][08 00][00] device not detected.
[00023371][01 00][00] v2.29.4149 -> v2.29.4149
[00023405][01 01][00] v2.29.4149 -> v2.29.4149
[00023464][04 00][00] v1.29.0.0 -> v1.29.0.0
[00023506][09 00][00] v0.0.0.0 -> v0.0.0.62 need upgrade.
[00023542]Done.
[00028140]Waiting for user confirm...
[00038176]Timeout, start upgrade automatically.
[00038250]Firmware upgrading[1]...
[00038325][09 00] Firmware upgrade start...
[00151492][09 00] Firmware upgrade finished successfully.
[00151525]Done.
[00151557]Version checking[2]...
[00151621][07 00][00] v1.0.9.22 -> v1.0.9.22
[00151669][08 00][00] v2.14.9.26 -> v2.14.9.26
[00151704][01 00][00] v2.29.4149 -> v2.29.4149
[00151743][01 01][00] v2.29.4149 -> v2.29.4149
[00151789][04 00][00] v1.29.0.0 -> v1.29.0.0
[00151830][09 00][05] v0.0.0.62 -> v0.0.0.62
[00151866]Packet upgrade finish successfully.
[00010590]========== remo-con disconnect. boot(15) ============
[00010631]Packet [C:\OSMO_FW_V01.02.01.60.bin] detected, card sn [0xa1622432].
[00010667]Packet upgrade start...
[00010714]Packet checking...
[00010753]Packet vlink 01.02.0160 <-> 01.00.0120.
[00010793]Record vlink 01.00.0119 <-> 01.00.0118 (flow = 0).
[00010830]Done.
[00010868]Version checking[1]...
[00010931][07 00][00] v1.0.9.22 -> v1.0.9.28 need upgrade.
[00010983][08 00][00] v2.14.9.26 -> v2.14.9.26
[00011026][01 00][00] v2.29.4149 -> v2.39.4359 need upgrade
[00011065][01 01][00] v2.29.4149 -> v2.39.4359 need upgrade
[00011111][04 00][00] v1.29.0.0 -> v1.29.0.13 need upgrade.
[00011180][09 00][00] v0.0.0.62 -> v0.0.0.65 need upgrade.
[00011216]Done.
[00013846]Waiting for user confirm...
[00023882]Timeout, start upgrade automatically.
[00023962]Firmware upgrading[1]...
[00029698][01 00] Firmware upgrade start...
[00007911][01 00] Firmware upgrade finished successfully.
[00007951]Done.
[00007988]Packet [C:\OSMO_FW_V01.02.01.60.bin] resumed, card sn [0xa1622432].
[00008036]Packet vlink 01.02.0160 <-> 01.00.0120.
[00008078]Record vlink 01.00.0119 <-> 01.00.0118 (flow = 0).
[00008119]Version checking[2]...
[00008185][07 00][00] v1.0.9.22 -> v1.0.9.28 need upgrade.
[00008239][08 00][00] v2.14.9.26 -> v2.14.9.26
[00008293][01 00][05] v2.39.4359 -> v2.39.4359
[00008336][01 01][00] v2.29.4149 -> v2.39.4359 need upgrade
[00008379][04 00][00] v1.29.0.0 -> v1.29.0.13 need upgrade.
[00008435][09 00][00] v0.0.0.62 -> v0.0.0.65 need upgrade.
[00008473]Done.
[00008516]Firmware upgrading[2]...
[00008610][01 01] Firmware upgrade start...
[00038889][01 01] Firmware upgrade finished successfully.
[00039398][07 00] Firmware upgrade start...
[00123135][07 00] Firmware upgrade finished successfully.
[00123198][09 00] Firmware upgrade start...
[00224204][09 00] Firmware upgrade finished successfully.
[00224276][04 00] Firmware upgrade start...
[00305816][04 00] Firmware upgrade finished successfully.
[00305945]Done.
[00305981]Version checking[3]...
[00306043][07 00][05] v1.0.9.28 -> v1.0.9.28
[00306101][08 00][00] v2.14.9.26 -> v2.14.9.26
[00306139][01 00][05] v2.39.4359 -> v2.39.4359
[00306178][01 01][05] v2.39.4359 -> v2.39.4359
[00306222][04 00][05] v1.29.0.13 -> v1.29.0.13
[00306303][09 00][05] v0.0.0.65 -> v0.0.0.65
[00306341]Packet upgrade finish successfully.
[00010563]========== remo-con disconnect. boot(15) ============
[00010601]Packet [C:\OSMO_FW_V01.02.01.60.bin] detected, card sn [0xa1622432].
[00010645]Packet upgrade start...
[00010688]Packet checking...
[00010729]Packet vlink 01.02.0160 <-> 01.00.0120.
[00010769]Record vlink 01.02.0160 <-> 01.00.0120 (flow = 0).
[00010807]Done.
[00010850]Version checking[1]...
[00012170][07 00][00] v1.0.9.28 -> v1.0.9.28
[00012223][08 00][00] v2.14.9.26 -> v2.14.9.26
[00012269][01 00][00] v2.39.4359 -> v2.39.4359
[00012308][01 01][00] v2.39.4359 -> v2.39.4359
[00012378][04 00][00] v1.29.0.13 -> v1.29.0.13
[00012431][09 00][00] v0.0.0.65 -> v0.0.0.65
[00014470]Packet upgrade cancelled at version checking.
[00010630]========== remo-con disconnect. boot(15) ============
[00010666]Packet [C:\OSMO_FW_V01.05.02.00.bin] detected, card sn [0x1af7cd51].
[00010701]Packet upgrade start...
[00010739]Packet checking...
[00010773]Packet vlink 01.05.0200 <-> 01.04.0180.
[00010816]Record vlink 01.02.0160 <-> 01.00.0120 (flow = 0).
[00010852]Done.
[00010888]Version checking[1]...
[00010949][07 00][00] v1.0.9.28 -> v1.0.9.48 need upgrade.
[00010993][08 00][00] v2.14.9.26 -> v2.14.9.42 need upgrade.
[00011028][01 00][00] v2.39.4359 -> v2.63.4998 need upgrade
[00011065][01 01][00] v2.39.4359 -> v2.63.4998 need upgrade
[00011107][04 00][00] v1.29.0.13 -> v1.29.0.91 need upgrade.
[00011166][09 00][00] v0.0.0.65 -> v0.0.0.78 need upgrade.
[00011201]Done.
[00013843]Waiting for user confirm...
[00023877]Timeout, start upgrade automatically.
[00024031]Firmware upgrading[1]...
[00029660][01 00] Firmware upgrade start...
[00020435][01 00] Firmware upgrade finished successfully.
[00020481]Done.
[00020518]Packet [C:\OSMO_FW_V01.05.02.00.bin] resumed, card sn [0x1af7cd51].
[00020560]Packet vlink 01.05.0200 <-> 01.04.0180.
[00020604]Record vlink 01.02.0160 <-> 01.00.0120 (flow = 0).
[00020641]Version checking[2]...
[00020723][07 00][00] v1.0.9.28 -> v1.0.9.48 need upgrade.
[00020779][08 00][00] v2.14.9.26 -> v2.14.9.42 need upgrade.
[00020817][01 00][05] v2.63.4998 -> v2.63.4998
[00020854][01 01][00] v2.39.4359 -> v2.63.4998 need upgrade
[00020905][04 00][00] v1.29.0.13 -> v1.29.0.91 need upgrade.
[00020953][09 00][00] v0.0.0.65 -> v0.0.0.78 need upgrade.
[00020998]Done.
[00021036]Firmware upgrading[2]...
[00021132][01 01] Firmware upgrade start...
[00031447][01 01] Firmware upgrade finished successfully.
[00032133][08 00] Firmware upgrade start...
[00527879][08 00] Firmware upgrade finished successfully.
[00528419][07 00] Firmware upgrade start...
[00611157][07 00] Firmware upgrade finished successfully.
[00611228][09 00] Firmware upgrade start...
[00738956][09 00] Firmware upgrade finished successfully.
[00739021][04 00] Firmware upgrade start...
[00799487][04 00] Firmware upgrade finished successfully.
[00799670]Done.
[00799703]Version checking[3]...
[00799760][07 00][05] v1.0.9.48 -> v1.0.9.48
[00799809][08 00][05] v2.14.9.42 -> v2.14.9.42
[00799846][01 00][05] v2.63.4998 -> v2.63.4998
[00799890][01 01][05] v2.63.4998 -> v2.63.4998
[00799935][04 00][05] v1.29.0.91 -> v1.29.0.91
[00800001][09 00][05] v0.0.0.78 -> v0.0.0.78
[00800037]Packet upgrade finish successfully.
[00054382]========== 2016.04.23 20:03:20. boot(15) ============
[00054423]Packet [C:\OSMO_FW_V99.99.99.99.bin] detected, card sn [0xfb2c2b51].
[00054460]Packet upgrade start...
[00054496]Packet checking...
[00054529]Packet vlink 01.06.0210 <-> 01.05.0200.
[00054563]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00054692]Done.
[00054727]Version checking[1]...
[00054767][01 00][00] v2.63.4998 -> v2.65.5033 need upgrade
[00054804][01 01][00] v2.63.4998 -> v2.65.5033 need upgrade
[00054850][04 00][00] v1.29.0.91 -> v1.29.0.92 need upgrade.
[00054900][09 00][00] v0.0.0.78 -> v0.0.0.81 need upgrade.
[00054941][08 00][00] v2.14.9.42 -> v2.14.9.42
[00054977]Done.
[00057010]Waiting for user confirm...
[00067048]Timeout, start upgrade automatically.
[00067129]Firmware upgrading[1]...
[00072792][01 00] Firmware upgrade start...
[00020311][01 00] Firmware upgrade finished successfully.
[00020350]Done.
[00020387]Packet [C:\OSMO_FW_V99.99.99.99.bin] resumed, card sn [0xfb2c2b51].
[00020435]Packet vlink 01.06.0210 <-> 01.05.0200.
[00020475]Record vlink 01.05.0200 <-> 01.04.0180 (flow = 0).
[00020514]Version checking[2]...
[00020552][01 00][05] v2.65.5033 -> v2.65.5033
[00020590][01 01][00] v2.63.4998 -> v2.65.5033 need upgrade
[00020645][04 00][00] v1.29.0.91 -> v1.29.0.92 need upgrade.
[00020702][09 00][00] v0.0.0.78 -> v0.0.0.81 need upgrade.
[00060774]HG310: update DM368 Check Version,Wake up DM368 time out
[00103345]HG310: update DM368 Check Version,Wake up DM368 time out
[00145921]HG310: update DM368 Check Version,Wake up DM368 time out
[00188497]HG310: update DM368 Check Version,Wake up DM368 time out
[00231072]HG310: update DM368 Check Version,Wake up DM368 time out
[00233614][08 00][00] device not detected.
[00233652]Done.
[00233688]Firmware upgrading[2]...
[00233769][01 01] Firmware upgrade start...
[00244034][01 01] Firmware upgrade finished successfully.
[00244097][09 00] Firmware upgrade start...
[00325311][09 00] Firmware upgrade finished successfully.
[00325379][04 00] Firmware upgrade start...
[00376721][04 00] Firmware upgrade finished successfully.
[00377199]Done.
[00377233]Version checking[3]...
[00377278][01 00][05] v2.65.5033 -> v2.65.5033
[00377315][01 01][05] v2.65.5033 -> v2.65.5033
[00377361][04 00][05] v1.29.0.92 -> v1.29.0.92
[00377506][09 00][05] v0.0.0.81 -> v0.0.0.81
[00417559]HG310: update DM368 Check Version,Wake up DM368 time out
[00460135]HG310: update DM368 Check Version,Wake up DM368 time out
[00502715]HG310: update DM368 Check Version,Wake up DM368 time out
[00545287]HG310: update DM368 Check Version,Wake up DM368 time out
[00587862]HG310: update DM368 Check Version,Wake up DM368 time out
[00590400][08 00][00] device not detected.
[00590436]Packet upgrade failed at version checking.
[00158394]========== 2016.10.14 09:28:44. boot(15) ============
[00158432]Packet [C:\OSMO_FW_V99.99.99.99.bin] detected, card sn [0xfb242bf9].
[00158471]Packet upgrade start...
[00158510]Packet checking...
[00158570]Packet vlink 01.08.0240 <-> 01.06.0210.
[00158605]Done.
[00158643]Version checking[1]...
[00158682][01 00][00] v2.65.5033 -> v2.70.5440 need upgrade
[00158727][01 01][00] v2.65.5033 -> v2.70.5440 need upgrade
[00158773][04 00][00] v1.29.0.92 -> v1.30.1.43 need upgrade.
[00158824][09 00][00] v0.0.0.81 -> v0.0.0.90 need upgrade.
[00167871][08 00][00] v2.14.9.42 -> v2.14.9.42 need upgrade.
[00167909]Done.
[00169946]Waiting for user confirm...
[00179980]Timeout, start upgrade automatically.
[00180063]Firmware upgrading[1]...
[00185811][01 00] Firmware upgrade start...
[00018331][01 00] Firmware upgrade finished successfully.
[00018373]Done.
[00018416]Packet [C:\OSMO_FW_V99.99.99.99.bin] resumed, card sn [0xfb242bf9].
[00018468]Packet vlink 01.08.0240 <-> 01.06.0210.
[00018518]Version checking[2]...
[00018552][01 00][05] v2.70.5440 -> v2.70.5440 need upgrade
[00018594][01 01][00] v2.65.5033 -> v2.70.5440 need upgrade
[00018648][04 00][00] v1.29.0.92 -> v1.30.1.43 need upgrade.
[00018711][09 00][00] v0.0.0.81 -> v0.0.0.90 need upgrade.
[00018755][08 00][00] v2.14.9.42 -> v2.14.9.42 need upgrade.
[00018794]Done.
[00018840]Firmware upgrading[2]...
[00018939][01 01] Firmware upgrade start...
[00029232][01 01] Firmware upgrade finished successfully.
[00029978][08 00] Firmware upgrade start...
[00529873][08 00] Firmware upgrade finished successfully.
[00529938][09 00] Firmware upgrade start...
[00585874][09 00] Firmware upgrade finished successfully.
[00585947][04 00] Firmware upgrade start...
[00640178][04 00] Firmware upgrade finished successfully.
[00640218]Done.
[00640260]Version checking[3]...
[00641154][01 00][05] v2.70.5440 -> v2.70.5440 need upgrade
[00641190][01 01][05] v2.70.5440 -> v2.70.5440 need upgrade
[00641261][04 00][05] v1.30.1.43 -> v1.30.1.43 need upgrade.
[00641319][09 00][05] v0.0.0.90 -> v0.0.0.90 need upgrade.
[00641363][08 00][05] v2.14.9.42 -> v2.14.9.42 need upgrade.
[00641403]Packet upgrade finish successfully.
[00126606]========== 2017.04.04 20:08:45. boot(5) ============
[00126645]Packet [C:\OSMO_FW_V99.99.99.99.bin] detected, card sn [0xfb2c2b51].
[00126685]Packet upgrade start...
[00126725]Packet checking...
[00126786]Packet vlink 01.08.0240 <-> 01.06.0210.
[00126826]Done.
[00126864]Version checking[1]...
[00126902][01 00][00] v2.70.5440 -> v2.70.5440 need upgrade
[00126950][01 01][00] v2.70.5440 -> v2.70.5440 need upgrade
[00126995][04 00][00] v1.30.1.43 -> v1.30.1.43 need upgrade.
[00127040][09 00][00] v0.0.0.0 -> v0.0.0.90 need upgrade.
[00136097][08 00][00] v2.14.9.42 -> v2.14.9.42 need upgrade.
[00136135]Done.
[00138173]Waiting for user confirm...
[00148207]Timeout, start upgrade automatically.
[00148290]Firmware upgrading[1]...
[00155302][01 00] Firmware upgrade start...
[00006542][01 00] Firmware upgrade finished successfully.
[00006584]Done.
[00006623]Packet [C:\OSMO_FW_V99.99.99.99.bin] resumed, card sn [0xfb2c2b51].
[00006683]Packet vlink 01.08.0240 <-> 01.06.0210.
[00006724]Version checking[2]...
[00006768][01 00][05] v2.70.5440 -> v2.70.5440 need upgrade
[00006807][01 01][00] v2.70.5440 -> v2.70.5440 need upgrade
[00006854][04 00][00] v1.30.1.43 -> v1.30.1.43 need upgrade.
[00006921][09 00][00] v0.0.0.0 -> v0.0.0.90 need upgrade.
[00007063][08 00][00] v2.14.9.42 -> v2.14.9.42 need upgrade.
[00007107]Done.
[00007149]Firmware upgrading[2]...
[00007245][01 01] Firmware upgrade start...
[00017544][01 01] Firmware upgrade finished successfully.
[00018225][08 00] Firmware upgrade start...
[00514709][08 00] Firmware upgrade finished successfully.
[00514776][09 00] Firmware upgrade start...
[00010689]========== remo-con disconnect. boot(15) ============
[00010725]Packet [C:\OSMO_FW_V01.08.02.40.bin] detected, card sn [0xfb2c2b51].
[00010762]Packet upgrade start...
[00010799]Packet checking...
[00010836]Packet vlink 01.08.0240 <-> 01.06.0210.
[00010873]Record vlink 01.08.0240 <-> 01.06.0210 (flow = 0).
[00010909]Done.
[00010944]Version checking[1]...
[00010994][04 00][00] v1.30.1.43 -> v1.30.1.43
[00011057][07 00][00] v1.0.9.48 -> v1.0.9.48
[00011114][08 00][00] v2.14.9.42 -> v2.14.9.42
[00011150][01 00][00] v2.70.5440 -> v2.70.5440
[00011185][01 01][00] v2.70.5440 -> v2.70.5440
[00011230][09 00][00] v0.0.0.0 -> v0.0.0.90 need upgrade.
[00011265]Done.
[00013302]Waiting for user confirm...
[00006696]========== remo-con disconnect. boot(5) ============
[00006741]Packet [C:\OSMO_FW_V01.08.02.40.bin] detected, card sn [0xfb2c2b51].
[00006783]Packet upgrade start...
[00006825]Packet checking...
[00006875]Packet vlink 01.08.0240 <-> 01.06.0210.
[00006916]Record vlink 01.08.0240 <-> 01.06.0210 (flow = 0).
[00006966]Done.
[00007005]Version checking[1]...
[00007055][04 00][00] v1.30.1.43 -> v1.30.1.43
[00007253][07 00][00] v1.0.9.48 -> v1.0.9.48
[00007305][08 00][00] v2.14.9.42 -> v2.14.9.42
[00007349][01 00][00] v2.70.5440 -> v2.70.5440
[00007391][01 01][00] v2.70.5440 -> v2.70.5440
[00007445][09 00][00] v0.0.0.0 -> v0.0.0.90 need upgrade.
[00007484]Done.
[00009524]Waiting for user confirm...
[00019561]Timeout, start upgrade automatically.
[00019639]Firmware upgrading[1]...
[00019713][09 00] Firmware upgrade start...
[00288514]========== 2017.04.04 20:45:43. boot(1) ============
[00288552]Packet [C:\OSMO_FW_V99.99.99.99.bin] detected, card sn [0xfb2c2b51].
[00288593]Packet upgrade start...
[00288643]Packet checking...
[00288698]Packet vlink 01.08.0240 <-> 01.06.0210.
[00288739]Done.
[00288780]Version checking[1]...
[00288822][01 00][00] v2.70.5440 -> v2.70.5440 need upgrade
[00288863][01 01][00] v2.70.5440 -> v2.70.5440 need upgrade
[00288910][04 00][00] v1.30.1.43 -> v1.30.1.43 need upgrade.
[00288977][09 00][00] v0.0.0.0 -> v0.0.0.90 need upgrade.
[00298017][08 00][00] v2.14.9.42 -> v2.14.9.42 need upgrade.
[00298057]Done.
[00300098]Waiting for user confirm...
[00310138]Timeout, start upgrade automatically.
[00310226]Firmware upgrading[1]...
[00317217][01 00] Firmware upgrade start...
[00006316][01 00] Firmware upgrade finished successfully.
[00006358]Done.
[00006407]Packet [C:\OSMO_FW_V99.99.99.99.bin] resumed, card sn [0xfb2c2b51].
[00006469]Packet vlink 01.08.0240 <-> 01.06.0210.
[00006512]Version checking[2]...
[00006553][01 00][05] v2.70.5440 -> v2.70.5440 need upgrade
[00006602][01 01][00] v2.70.5440 -> v2.70.5440 need upgrade
[00006650][04 00][00] v1.30.1.43 -> v1.30.1.43 need upgrade.
[00006707][09 00][00] v0.0.0.0 -> v0.0.0.90 need upgrade.
[00006749][08 00][00] v2.14.9.42 -> v2.14.9.42 need upgrade.
[00006799]Done.
[00006840]Firmware upgrading[2]...
[00006935][01 01] Firmware upgrade start...
[00017222][01 01] Firmware upgrade finished successfully.
[00017902][08 00] Firmware upgrade start...
[00520281][08 00] Firmware upgrade finished successfully.
[00520348][09 00] Firmware upgrade start...
[00012560]========== remo-con disconnect. boot(15) ============
[00012600]Packet [C:\OSMO_FW_V01.04.01.80.bin] detected, card sn [0xfb2c2b51].
[00012648]Packet upgrade start...
[00012690]Packet checking...
[00012730]Packet vlink 01.04.0180 <-> 01.02.0160.
[00012773]Record vlink 01.08.0240 <-> 01.06.0210 (flow = 6).
[00012821]Packet upgrade failed at packet checking.
[00012664]========== remo-con disconnect. boot(15) ============
[00012704]Packet [C:\OSMO_FW_V01.08.02.40.bin] detected, card sn [0xfb2c2b51].
[00012745]Packet upgrade start...
[00012795]Packet checking...
[00012837]Packet vlink 01.08.0240 <-> 01.06.0210.
[00012880]Record vlink 01.08.0240 <-> 01.06.0210 (flow = 0).
[00012929]Done.
[00012971]Version checking[1]...
[00013018][04 00][00] v1.30.1.43 -> v1.30.1.43
[00013109][07 00][00] v1.0.9.48 -> v1.0.9.48
[00013160][08 00][00] v2.14.9.42 -> v2.14.9.42
[00013200][01 00][00] v2.70.5440 -> v2.70.5440
[00013239][01 01][00] v2.70.5440 -> v2.70.5440
[00013310][09 00][00] v0.0.0.0 -> v0.0.0.90 need upgrade.
[00013351]Done.
[00015394]Waiting for user confirm...
[00025441]Timeout, start upgrade automatically.
[00025529]Firmware upgrading[1]...
[00025591][09 00] Firmware upgrade start...
End of log
Can you help me with this?
Thanks
Cheers
Yovandra
