NEW FIRMWARE TODAY v01.03.0550
1995 15 2017-4-5
SashaSWISS
Flight distance : 1534478 ft
Switzerland
Experience ??
2017-4-5
trica de
Flight distance : 1062090 ft
i will install it later - looks like SMALL changes
2017-4-5
SHamers
Flight distance : 1001020 ft
Is .0550 also add the option to cancel auto-landing again?
2017-4-5
fans85982ddf
Lebanon
refuse to update. when the magic pro restarts during the update it disconnect and stop the update.
any solution?
2017-4-6
hallmark007
Flight distance : 9827923 ft
It was out yesterday, installed and everything working fine, no problems.
2017-4-6
digitalintruder
Flight distance : 3652379 ft
fans85982ddf Posted at 2017-4-6 12:58
any solution?
This doesn't help you, but mine worked fine.
I used the DJI Assistant 2 app to install the firmware and it went through in about ~ 10 minutes for the mavic and about 2-3 minutes for the controller.
I find that the disconnection w/ the RC controller and app crashes make using the controller unreliable to do firmware updates.
2017-4-6
fans85982ddf
Lebanon
digitalintruder Posted at 2017-4-6 13:40
even with the assistant 2, the update fail at 65% when the drone restarts
i retry it 20 times
2017-4-6
digitalintruder
fans85982ddf Posted at 2017-4-6 14:11
i retry it 20 times
Argh, Sorry to hear that =( Any word from DJI to help you correct this episode?
2017-4-6
bomberuk
Flight distance : 16759 ft
im staying on version 400 as everything is fine,the update isent a big enough deal anyway,also litchi dosent work properly with the last two firmwares either .
2017-4-6
fansfc3e3ebf
Flight distance : 387608 ft
Can you postpone or avoid the firmware upgrade?
2017-4-6
fans01dd4a2b
Hi all if u have Sony x5 don't update for now. As soon as I updated I got a Gimbal overloaded error. Tried restarting and recalibration etc but no use.  Will wait to see if anyone else faces the same issue if not will reach out to dji
2017-4-6
SashaSWISS
Switzerland
update worked like a charm. without any problems...and it flys perfectly!
2017-4-7
tellus1
Flight distance : 105551 ft
Updated tonight, will test tomorrow. None of my batteries needed updating... is that the same for everyone else? I was on .500
2017-4-7
DJL
Flight distance : 795810 ft
I updated yesterday to v01.03.0550 using the djigo 4 app and my iphone7 plus on my home wifi. The update went smoothly without any problems, all my setting remained intact and flew a few quick flights without any problems.
2017-4-7
DASFREAK
Flight distance : 4446 ft
I read what was updated, but there isn't any details.  Does anyone know exactly what was tweaked with the RTH and the hovering?
2017-4-7
wittmann
Flight distance : 667408 ft
It turned me into a newt!
i got better....
2017-4-7
