Mike-the-cat
Flight distance : 22488593 ft
Singapore
Using 'none' as the color setting, I've observed:
The P4P has a blue bias while the I2 has a very strong earthy tone bias, particularly when the sun is at a low angle in the sky.
In bright sunshine they are about the same
In cloudy weather, the P4P footage tends to have a cooler cast.
If you are a pro - use Raw with the I2.... under challenging conditions
