AACY
Flight distance : 518012 ft
Yhadar Posted at 2017-4-7 04:40
When reaching 3.6v, what percentage is it (about)?
Thanks,
Sure, 3.6Volts is about 25% of the capacity of the cell. With LiPo batteries you must always be careful since the behavior of them is not linear, it's exponential meaning that the closer you get to the extremes of the battery capacity its more unstable.
The Mavic uses 3cell batteries meaning that it's working voltage is 11.1 volts. At 3.6volts you are at 10.8volts per battery pack which is quite unstable and the drone might enter in a power loss. This also explains why you must be very careful at low capacities when flying because any harsh input in the sticks and rapid acceleration of the motors will generate a power drop which the drone will not like, causing the ESCs to enter in a self protection mode and shutting down. Which will not be of any good if you are still flying.
Hope this helps!
