InspiredAviator
Flight distance : 4948530 ft
South Africa
Good evening fellow droneers,
I had to update our companies' Inspire1 after taking it out of the box. I updated the Inspire1 itself with 100% success (SD card in the camera and .bin file method).
When I attempted the update on the controller via the DJI GO app (iOS), it showed the firmware was downloaded(normal), and then I proceeded with the update. The progress bar stayed on 0% with the controller emitting the update beep....... It stayed like that for an indefinite period, and I did not take note that the phone was running out of battery. It died, and the beeping on the controller stopped.
When I restarted everything and checked the controller, it no longer had an update available. I checked the installed firmware versions and the Inspire checked in at V1.10.x, whilst the controller checked at V1.7.x.
Does this sound remotely correct? (pun intended)
Looking forward to the feedback!
P.S. I also tried the USB method after thinking the difference in versions indicated that the update had failed. Nothing happened.
