How to install latest firmware (FW)
12345Next >
32794 165 2015-3-1
dundee
Flight distance : 33550 ft
Thailand
How to install Latest Firmware
Download Latest Firmware
   - Inspire1 Platform                  (WM610_FW_V01.02.01.06.bin)
   - Phantom P3 Professional    (P3X_FW_V01.02.0006.bin)
   - Phantom P3 Advanced        (P3S_FW_V01.02.0008.bin)
t2
t2
t1
t1
Related Links
2015-3-1
UM305
Thank you for sharing!
2015-3-1
MJDMike
Nice work, thanks for taking the time to do this.
2015-3-1
arunmehta
Flight distance : 120909757 ft
Good Work Thanks for sharing
2015-3-1
Andy C
Thank you, a lot clearer way to understand the process and may attempt it tomorrow without any distractions at home.
2015-3-1
Bobbybee
Thank you for this
2015-3-1
littleninja72
United Arab Emirates
Great work Dundee. I was bit confused regarding the procedure as I taught we had to use the APP (Tx ON) to update but seems that this version just required to slide in the card  in the Gimbal/Camera and turn ON the Inspire.
2015-3-1
rfrye
Flight distance : 309606 ft
dundee Posted at 2015-3-1 19:58
Maybe these 2 flowcharts can help some members.
Great work Dundee !
2015-3-1
dundee
Thailand
These are my results after following the flowcharts.
2015-3-1
rfrye
Dundee,
I format my new SD cards in the Inspire-1 gimbal by hitting "Format SD Card" under the app "General Settings" menu.
Do you agree with this new card formatting procedure. If not, exactly how do I format it to FAT?
When I download my new zip file it goes to a VLC media file signification. Why? Is this ok?
I really appreciate your help, Dundee.
2015-3-1
dundee
Thailand
rfrye Posted at 2015-3-1 22:06
Dundee,
I format my new SD cards in the Inspire-1 gimbal by hitting "Format SD Card" under the ap ...
Just put the SD-Card into your computer (not the Inspire1) and format it.
You have to put it into your computer anyway to copy the firmware onto it.
2015-3-1
mgmelectric2
Awesome work Thanks !!
2015-3-1
Clem2099
dundee Posted at 2015-3-1 22:05
Thanks Dundee, very good flow chart.  How do I get to this screen that you are on?
2015-3-1
rfrye
Is this for IOS?
Doesn't look like mine, but I'm on Android 4.2.2
Regardless, my app will not call for an update. It says "Firmware Latest-Normal" on the firmware prior to the new firmware release. Why? I ignored this, and tried to download the new firmware and it would not take ?????
Pretty confused here. "DJI-Help-Line" guy told me if I have Android it updates automatically. Can I believe this?
Pretty sure I can speak for a lot of us that we really appreciate your help and insight.
here's what mine says:
2015-3-1
rfrye
Here's what mine says:
2015-3-1
dundee
Thailand
Clem2099 Posted at 2015-3-1 22:13
In the APP DJI Pilot (on your device)
1) Click General Settings (Top right)
2) Scroll down to 'About' and select that.
2015-3-1
Clem2099
dundee Posted at 2015-3-1 22:23
2) Scroll down to 'Abo ...
Thank you. Is that were the flight log would be also?
2015-3-1
dundee
Thailand
rfrye Posted at 2015-3-1 22:22
Looks like firmware version numbers can be different between IOS and ANDROID.
When i compare yours with mine, they look ALMOST simular. (but yes, confusing)
Don't be confused anymore.
After updating your SD-Card will contain :
  - The binfile WM610_FW_V01.02.00.17
  - The created file WM_610_FW_RESULT_GS
Open the created file WM_610_FW_RESULT_GS
If you see 'Result: success' then it's updated.
If you see 'Result: cancel'  then it's still OK and updated.
Every time you power up the Inspire1, if will first read the SD-Card.
If the binfile WM610_FW_V01.02.00.17 is there, it will try to update.
If it was not updated, it will for the next 25minutes and then create the WM_610_FW_RESULT_GS
If it was already updated, it will overwrite 'Result: success' with 'Result: cancel'
It will not even try to update if the binfile WM610_FW_V01.02.00.17 is not on the SD-Card
So in short: 'success' or 'cancel' indicates that the craft is updated.
What many members do is, update, then power off.
But if you not look for success on the SD-Card and just power on again, it will be overwritten with 'cancel'
because it was already updated. So this way you never see success, only cancel
Kapido ??
2015-3-1
dundee
Thailand
Clem2099 Posted at 2015-3-1 22:40
Nope, for the flightlog(s) you need to connect the tail-connector of the Inspire1 to your computer usb-connector
The flightlog(s) are on the internal SD-Card of the Inspire1
2015-3-1
Clem2099
dundee Posted at 2015-3-1 23:13
Nope, for the flightlog(s) you need to connect the tail-connector of the Inspire1 to your computer ...
Thank you Dundee.  I see you helping lots of others and it is greatly appreciated, especially a noob like myself
2015-3-1
thumpinhard
Really well done! thanks so very much for doing this. i have been ok with my updates but i keep seeing others having issues and it is awesome to have really clear info in case i did have an issue. i think you should try to get this to dii and they should hire you to do the whole manual and keep it updated!..come on dii..the manual is NOT ACCURATE AND NOT COMPLETE!
2015-3-1
dundee
Thailand
thumpinhard Posted at 2015-3-1 23:36
Really well done! thanks so very much for doing this. i have been ok with my updates but i keep seei ...
Thank you for this complement
2015-3-1
Wildcat Willie
Thanks Dundee...Nice work and Thank You for taking the time  to put this together. Very helpful and professional.
2015-3-1
rfrye
Dundee,
When I double click on my bin. file I get the message shown below.
It can be changed from what I can tell (with a drop down of menu of options)
Can you tell me what  I should change this to, so it functions correctly and opens?
This probably why my aircraft won't recognize the file -right?
2015-3-1
arunmehta
rfrye Posted at 2015-3-2 00:11
Dundee,
Bin file is not to be clicked the RC and the Bird read it automatically on boot and do the DDDD and when finished D-DD
2015-3-1
rfrye
Dundee,
Dundee,
I for got to tell you I reformatted the SD card (which erases it's contents) and reloaded the new upgrade file but it still comes in as a VLC designation.
2015-3-1
dundee
Thailand
Dundee,
You don't have to open the binfile.
If you could, it would be unreadable anyway.
The binfile is there to copy it onto your SD-Card or Memory-Stick
After updating you open the WM610_FW_RESULT_GS textfile to check the result
2015-3-1
dale.kaechler
Good flow chart. I install firmware to the RC first then the I1.
2015-3-1
rfrye
dundee Posted at 2015-3-2 00:16
The binfile is th ...
Then "the VLC" has nothing to do with my aircraft not taking the upgrade  - right?
2015-3-1
bubo_bubo
Very helpful Dundee cheers, been putting this off, think I might give it a go now!
2015-3-1
RichJ53
Flight distance : 1837356 ft
Hey Dundee, nice job!!  Sounds like there are many ways to get confused along the way.
Now is this a guideline or a rule?
2015-3-1
rfrye
RichJ53 Posted at 2015-3-2 01:02
Now is this  ...
Rich,
I believe Dundee is "THE MAN"!
He should probably be writing DJI Inspire-1 Firmware Manual Instructions.
I'm following his instructions and it seems to be working. I'll  be able to tell you in an hour.
I vote for Dundee to be Inspire-1 Firmware Advisor. He's been pretty darn generous to a lot of us with his time and quality advice. DJI should take note and send him a nice fat check.
(I wonder where he's from - Australia maybe?)
2015-3-1
dundee
Thailand
rfrye Posted at 2015-3-2 00:27
No it does not
2015-3-1
dundee
Thailand
Now is this  ...
Believe me, i put some time in this problem.
Let us first see how many members will post here "The rule of Dundee: Result: success"
This works Rich, although i think DJI should make this more user friendly.
2015-3-1
pidetectives
Flight distance : 2131073 ft
I have not been able to update the bird and this is by chart (ANDROID HERE) but have been able to update RC
2015-3-1
Colonel Angus
Awesome stuff Dundee TY !!
2015-3-1
dundee
Thailand
pidetectives@ya Posted at 2015-3-2 01:34
Hi pi..., this picture indicates you have the latest version installed.
2015-3-1
pidetectives
dundee Posted at 2015-3-2 01:41
Weird never got any DDD or DA DA DA of any kind. only on the remote
2015-3-1
dundee
Thailand
pidetectives@ya Posted at 2015-3-2 01:42
Yes weird, thats why i wrote on the flowchart :
No D---DDD sound after 45 minutes ?
  Just continue with the next step
2015-3-1
pidetectives
Yes I saw that . By the way great job with the chart.
2015-3-1
12345Next >
