converting footage?
dronedronedrone
Hi all,  I've shot some footage in 4K and it's  really difficult to
edit in premiere pro (jerky + choppy in play back)  is there a was to convert the footage to 1920 x 1080?
2017-4-9
Cetacean
Flight distance : 2528264 ft
Aloha drone,
     Download the GoPro Studio software.  It is free.  It will convert your video to a .mov and then you can convert it to whatever you want.
Aloha and Drone On!
2017-4-10
Skyclip
Flight distance : 347940 ft
https://helpx.adobe.com/premiere-pro/how-to/proxy-media.html
2017-4-10
christing
Japan
The recorded MOV/MP4 files are compressed using the h.264 codec, which is final delivery codec and it is not one you want to use for editing. Plus, granted, Premiere Pro CS6, CC can handle (usually) 4K files without much problem, but it is extremely hardware intensive. On this circumstance, if you are stick to editing Phantom 4K videos in Premiere Pro, you'd better convert them to a more editing-friendly format in 1080p.
Actually, it's not as difficult as you imagine. What's need is a just a common video converter like Brorsoft Video Converter for Mac - The program works as the best Mac DJI Video Converter. It helps you fast transcode DJI Phantom 4, DJI Phantom 3, DJI Phantom 2 footage to Premiere Pro preferred MPEG-2 in 1080p with fast encoding speed and without quality loss.
2017-6-14
pasaytenpete
Flight distance : 47346 ft
Cyberlink PowerDirector 15 handles DJI 4K videos fine...   :-)
2017-6-14
Xavier1984
Flight distance : 1579088 ft
Switzerland
Hi,
One of the standard/pro solution is that in fact you not often edit your footage in native resolution (4k) due to big resources usage ! You need to use proxy media un der Adobe Premiere Pro CC. It's a process that  generate low resolution footage (it's a copy of the original footage but a an lower resolution), you edit and you can switch in realtime between the low and the full resolution file ! When you export your video the native (full) resolution is automatically and always used !
It takes juste some time to generate proxy video but after it's a real gain.
Enjoy ;-)
2017-6-14
Young66
Russia
Granted, Premiere Pro CS6, CC 7 can handle (usually) 4K files without much problem, but it is extremely hardware intensive.  You can have a try to encode the videos first before editing.
2017-6-21
monica66
Japan
Refer to:
http://brorsoft.com/how-to/downscale-4k-to-1080p.html
2017-9-12
Elena forbes
Work 4K Video Footage with Premeire Pro
2017-11-14
