Uptowndisco
Flight distance : 7394987 ft
Electro-Nick Posted at 2017-4-12 15:39
While you're at home with an internet connection open DJI Go and tap to enter Go Fly (you don't need the aircraft to be powered on). Once in the flight screen, make sure you have the map caching set to enabled in the settings screen, then tap the map to make it full screen and simply move the map display to the area you want to fly in, then move ithe map around and zoom in/out of the area you need to force the app to cache the map. Do a zoom in-out as there are different levels of detail on the satellite mapping imagery. Then power off the iPad/iPhone and go travel to the fly zone. When you next open the djigo app, the cached map will be available to you to use. It is that simple ;)
The benefit of the Android GO 4 map is you can download a complete country if you wanted to use
for offline use , would be nice to have this on ios but I understand the issues with providers. |
