Setting to control pan and tilt speed?
5490 4 2017-4-12
Marty Markoe
Flight distance : 15135 ft
My Phantom and Mavic gimbals speed of pans using control stick movement can be controlled through settings in the DJI GO app. Is there any way of doing this with Osmo Mobile?
Marty
2017-4-12
Marty Markoe
It turns out there is a setting to slow down the gimbal pan. It was confusing because it is called Fast Configuration in Settings - Gimbal. The Osmo Mobile pan now works like a charm.
Marty
2017-4-15
Terry Pilot
Hey Marty, Maybe you can help me. using DJI GO 4. In the camera settings, under the advanced menu, i can adjust the gimbal Pitch Speed, and other settings. But it has no effect. I do this with the quad turned on and connected. When i shut down and restart it shows all my new settings but still does not have an effect. There must be some other button i need to select? Thank you in advance for you help.
2017-4-16
Terry Pilot
thanks for the quick reply. I don't know what OSMO is, but I too can adjust it in the settings of the DJI GO app. And the settings get saved, but it doesn't change the speed
2017-4-16
Marty Markoe
Terry Pilot Posted at 2017-4-16 18:45
The Osmo Mobile is a handheld video stabilization device for mobile phones. Perhaps, you would be better off asking your question in one of the Phantom forums.
Marty
2017-4-17
