Camera P3 Advanced Not Centered
Whitetail UP
I just purchased a P3 Advanced from someone on Ebay, I haven't acutally hooked up a display to it yet, but when powered on the camera appears to be point to the left about 35 degrees. I haven't check flight logs etc to see if the unit was crashed, as I was told it was not.. but will.. the camera moves up and down as it should though. Is there anyway to adjust the unit back to centerline, or did I buy junk?
2017-4-12
Space Drone
Flight distance : 53862 ft
Try to do an IMU calibration then a gimble calibration. Hope this works and good luck with your maiden flight!
2017-4-12
Gr8audioguy
Flight distance : 15226 ft
I have the exact same problem with my P3Pro since it came out of the box last month. I hope someone can help us!
2017-4-12
johnsr
Flight distance : 1579022 ft
If the IMU and Gimbal calibration procedures do not help, you might check out the set-screw on the gimbal yaw shaft. The shaft has a flat upon which the set-screw should be correctly tightened. Use a small dentist's mirror to look under the shaft.
Have fun & good flying!
2017-4-12
Gr8audioguy Posted at 2017-4-12 20:08
Please try with Space Drone's advice and let us know if it helps.
2017-4-13
Gr8audioguy
DJI Mindy Posted at 2017-4-13 03:46
Well, thay's progress.... The gimble cal works but needs to be done at every power up.
2017-4-26
DJI-Jamie
Flight distance : 112405 ft
Gr8audioguy Posted at 2017-4-26 15:14
Well, thay's progress.... The gimble cal works but needs to be done at every power up.[view_image]
Did you do both the IMU and gimbal calibration in that order to see if it's more consistent at start up?
2017-4-26
Gr8audioguy
Here is a pic
2017-4-26
Gr8audioguy
DJI-Jamie Posted at 2017-4-26 15:17
Didn't do IMU - Will after battery charges
2017-4-26
DJI-Jamie
Gr8audioguy Posted at 2017-4-26 15:28
Please keep me posted.
2017-4-26
