mikes1
Flight distance : 1740699 ft
zzz Posted at 2017-8-23 09:13
I am new to this expansion kit, and still wondering if we need to buy it. So what it specifically can do with m600 for what kind of jobs?
I only find some video that simply on/off the LED light and small run motors which doesn't make much sense.
The expansion kit will allow you to turn strobe lights on or off, work servos that control different things, control a three-axis gimbal for an additional camera like the FLIR VUE Pro, control a release hook to drop items to stranded people. You can think up a lot of uses. If you don't want to do any of those things then the expansion kit is not needed. The other issue I have had since installing the kit was the issue of using a second POV camera. Before the kit was installed I could use a 10' HDMI cable and plug it into a 24" monitor and view the second camera on the external monitor while watching the DJI camera on the Ipad. Unfortunately, that option was lost after installing the kit. I can only see one or the other camera on the two devices but not both at the same time. DJI has still not fixed the issue and I don't know if they can. |
