raefsellous
New Zealand
Thank you both for your replies! Means a lot.
I watched the video, and tried to follow your comments, Joe, but it doesn't seem to separate.
I've attached a picture of the motor in question:
In the picture of the underside of the motor, you can see I've removed the circlip and the washer, but the shaft will still not move through the bearing.
In the picture with letters, I'm assuming that "A" is separate from parts "B,C,D" and will separate out the bottom while "B,C,D" stay as a unit and can be extracted toward the top of the picture?
The bottom
Side on view
