Analyses on SRW-60G Camera Incompatibility Issues
128 2 2017-4-12 22:05:53
DJI Support
China
5D3 Camera:
1. When the viewfinder is enabled in Photo mode with the 5D3 camera, there is no image transmission, because no data is output via HDMI. When an image is captured in the camera display, image transmission will be interrupted for about 10 seconds, because the HDMI output is interrupted for four seconds.
2. When a photo is captured in Video mode with the 5D3 camera, image transmission will be interrupted for about 13 seconds, because the HDMI output is interrupted for about 10 seconds.
3. In Video mode, image transmission will not be interrupted no matter recording starts or stops.
5D4 Camera:
1. When a photo is captured in Photo mode with the 5D4 camera, image transmission will not be interrupted.
2. In Video mode, when recording starts, the screen will freeze for about two seconds because the HDMI output is obstructed for two seconds. But image transmission will not be interrupted.
GH4 Camera:
For GH4 camera, image transmission will not be interrupted when the HDMI output resolution is set to 1080p.
If HDMI output resolution is set to 4K, there is no image transmission because the SRW-60G and Lightbridge 2 do not support 4K.
A7-S2 and A7-6300 Camera:
1. When a photo is captured in Photo mode with the A7 camera, image transmission will not be interrupted.
2. In Video mode, when the image resolution is set to 4K and recording starts, image transmission will be interrupted for about 10 seconds. When the image resolution is set to 1080p, image transmission will not be interrupted.
Camera
Photo Mode
Video Mode
Remarks
GoPro
Not interrupted
Not interrupted
5D3
Interrupted for about 13 seconds when recording a 4K or 1080p video.
Not interrupted
5D4
Not interrupted
Not interrupted, but the screen freezes for two seconds.
GH4
Not interrupted when the HDMI output resolution is set to 1080p.
No image transmission when the HDMI output resolution is set to 4K.
The HDMI output resolution is set to 1080p.
A7-S2
Not interrupted
Interrupted for about 10 seconds at the beginning when recording a 4K video.
Not interrupted when recording a 1080p video.
A7-6300
Not interrupted
BMCC (Blackmagic Cinema Camera)
N/A
Not interrupted
Red Scarlet
N/A
Not interrupted
ARRI
N/A
Not interrupted
2017-4-12 22:05:53
Jesper J
Hobbyist
Denmark
Canon 70D is also interrupted when taking fotos, even when preview is disabled on the camera, its takes about 10 seconds before the picture comes back.
2017-4-20 03:20:42
3x3q
Hobbyist
Flight distance : 248281
Thanks for this post.
It's also worth noting that it's not a fault of SRW-60G with Canon 5D3, in my case. I have bypassed SRW-60G and experienced the same 10-second or so delay after taking a photo.
2017-4-20 16:36:42
Close
DJI RecommendsPrevious /1 Next
