rockingsoul3577
Jamaica
I noticed a similar thing on my controller. I am using the latest app (4.0.7 (2860) and firmware (1.03.0600). The reason I noticed this was because, upon initially updating my Mavic Pro, I noticed that the drone was drifting, or rather, moving without any input commands. It would actually move in any direction (up, down, forward...). So I looked at the controller calibration and went through the process of trying to calibrate the controller. Now it always states the it is 3 or 4 % off to the right.
Also, I now notice that the drone is not as stable as it once was. When the drone is hovering even 3-4 feet off the ground, you can see the drone rocking a little even if there is very little/no wind. I think DJI needs to look at the firmware update again. I had no problems before this update.
Where can I download the DJI Assistant 2? Can I use this to downgrade the firmware back to a previous version? |
