Phantom Robin
Flight distance : 128839 ft
Belgium
hallmark007 Posted at 2017-4-13 08:35
I suppose the question is what would Mavic Pilots do with Atti mode, most dji aircraft have a switch to go into Atti mode, if you ask phantom pilots or inspire what do they use Atti for, 99.9% will tell you they will use it if they happen to loose gps. Yes there are a few who turn it on because you can travel faster, but that's very few.
So they loose gps they can now use Atti mode so that's the same as Mavic pilots, I have my Mavic since November 2016, only once have I lost gps and gone into Atti mode for about 3 minutes, and I know there have been some around here that say it takes a while to kick in, but for me it was instant, I was flying forward with throttle and the aircraft started to go forward and left I stopped pushing forward but the aircraft continued to go forward and left, it took awhile to get my bearings and in this time Mavic had moved a further 60m before I could see my inputs having an effect, I controlled it somewhat using radar for direction, soon after I regained gps.
I have been taught if your aircraft goes into Atti mode the first thing you should do is find a safe place to land and do it as soon as you can, raising your AC gives your aircraft a better chance to regain gps.
Not loosing GPS , loosing a functional compass, if the mavic has no GPS, Atti is automatically selected, if the compass if wrong, then manual Atti is necessary |
