Which is better P4P or the New P4 Advanced?
1560 9 2017-4-13
InThisLifeOrThe
Flight distance : 4856 ft
Which is better of the two and why?
2017-4-13
Snowwolfwarrior
Flight distance : 1064780 ft
Is it a phantom 4 with the pro camera attached ? My P4 was a very reliable bit of kit
2017-4-13
Antonio76
Flight distance : 144403 ft
Denmark
difficult to give an informed answer, since I think nobody (end users) have tested the new one yet...
2017-4-13
Delta Nine
I think the only difference is the P4P has dual wi-fi frequencies 2.4 and 5.8, whilst the P4A does not.
2017-4-13
theGrindLab.com
Flight distance : 1375846 ft
Define "better" and you might get some more accurate answers (once users have actually tried the newer product). Based on (my assumption of) specs though, I cannot see why the Advanced would be better than the Pro aside from having a lower price.
2017-4-13
Antonio76
Denmark
Delta Nine Posted at 2017-4-13 07:16
and back and side sensors...
2017-4-13
DJI-Jamie
Flight distance : 112405 ft
The term "better" is really dependent on the user and their needs. Here is the Specs and FAQ page for the P4A:
http://www.dji.com/phantom-4-adv/info#faq
The FAQ does compare the P4P vs the P4A along with the P4 vs P4A. A lot of the "enhances" that are mentioned come when comparing the P4 to the P4A. When comparing the P4P to the P4A, it's really comes down to how many "bells and whistles" do you want? The P4A takes out the side and backwards sensors, but the forward and downward sensors are the same between it and the P4P. Because those are missing, some of the intelligent flight modes that required those sensors were removed. This in turn reduced the price point. The P4A's "Plus" RC will act the same as the P4P's version, minus the 5.8 GHz frequency.
2017-4-13
Punchbuggy
Flight distance : 483166 ft
DJI-Jamie Posted at 2017-4-13 08:42
And just to add to Jamie's post, he mentions that due to sensors being the same as the P4 (i.e no rear and side) some intelligent flight modes therefore aren't available. An example of this is TapFly Backwards.
Another of note is that DJI are using the new lighter shell (as on the P4P) for it. So it isn't quite a P4 with advanced camera strapped on...
2017-4-13
DJI-Jamie
Just as a FYI (I know I've contributed to this thread as well), it would be best to have the conversation continue on the thread below so that the same topic is condensed in one place:
http://forum.dji.com/thread-92437-1-1.html
2017-4-13
dhimmakada
Banned
India
2017-6-23
