Deanopeps
Flight distance : 233474 ft
Hi all,
Fairly new to the Inspire 2 and have a few questions about the FPV Camera
- Is it possible to have the FPV Camera as the full screen? Having the other camera in the background can be a bit confusing i find at the moment (coming from a P4)
- Re-sizing of the FPV screen - I have now found I can re-size the FPV screen using 3 fingers (Thanks to another topic here) but seems to be a limit to the usual centre screen size?
I would like the above as I am trying to film a moving object using Active Track in Profile mode where the camera sits alongside the moving object but it is quite fast moving and sometimes it looses it and then i loose my orientation. I think switching to Full screen (not just the screen in the middle) FPV using the C1 button would help? I have also set up the C2 to centre Yaw on the main camera but then i have to try and lock onto the fast moving object again.
Or maybe you guys do this a different way? maybe once lost contact RTH but it is the shots i am after and batteries run out quick and i still only have one set!
And just to add a bit of complication and risk it is all at sea
Thanks
