Sorry to say, that DJI took a long time for this feature when the Inspire 1 was introduced. They want to make sure that the new feature works correctly before releasing it to the public.
I can say that AutoFlight Logic Autopilot is a very good third party App solution. It will take some time to learn but it has many more capabilities and awesome support. Links below
Rich
I'm also waiting from a long time to use the waypoint mode in GO4.
Now I began to learn, at least at the theoretical level, Autopilot. It's well documented and well done.
What puzzles me is that I've read in the Dji site - I can not remember where - that the use of apps other than GO4 invalidate the warranty. Does anyone else read anything like that?
Hi Blackwood! How you proposed above, at the moment I'll experiment the DJI GS PRO app. I was not knowing this app ...and probably it don't invalidates the i2's warranty. It do it?
Thank you.
This forum is ever useful.
But I believe the waypoints feature in Go4 app requires you to first fly the waypoints to create the route. I don't believe it has the capability to preprogram the waypoints like you can do with Litchi or Autopilot.
Viper Pilot Posted at 2017-6-23 11:21
Yes you are correct, limitations from DJI, also max distance from HP is 500 meter. But you can save the mission so you only have to do the flight once.
DJI GS Pro now works for the Inspire 2. However, I believe that it is iOS only. FPV Mission Planner is a paid-for add-on app that I also use. It includes "Orbit" missions - AKA "POI".
Cobra44Magnum Posted at 2017-7-6 09:07
That's right. GS Pro (also known as Ground Station Pro) is an iPad app designed to control or plan automatic flights for DJI aircraft.
