LynxLV
Flight distance : 75207 ft
Latvia
Messed up while inverted. Hit tree branch and my baby (PS3) trough branches fell on the ground. Thought fall seemed to be soft, it did break one proppeller and anti vibration camera plate. This all seemed to be easy fix.. But then i saw that grey cable that is conetcted from drone to camera is all puled apart. All wires were puled out of plastic pin. Also this seemed to be easy fix.. just to stuff all wires back into pin. But this is where it got tricky. Pin has 10 holes, but there are only 8 wires. So wich holes do i skip.. First i just pluged all from one side leaiving holes 9 and 10 empty. Turn on drone.. Gymbal and camera not responding. I searched. Found a diagram that said i should use holes 1,2,3,4 and 7,8,9,10. Did that.. For ar brief moment I got response from camera (camera feed) and gymball worked. Buut, drone itself iresponsive. It had no telemetrics, battery status N/A, and show that remote controler signal weak. So i assumed, thad wireing is not OK. Tried one more time, bet then i could get only gimball responsive, no video feed. Decided to look for more wiring schemes. Cheked for more videos. In one video I saw an orginal cable being taken of. It had holes 1 and 2 empty, so i rewired pins it this maner. In this way I had 0 progress. When attached drone just becomes iresponsive. Doesnt say anythiing doesnt do anything. As soon as I pull out cable drone lights turn on. when camera was completly unanatached, then I was able to arm my drone, but still in app got mesage of weak RC signal and no drone data at all.
So whats the corect wireing? Have I messed up smth with placing wires wrongly? Maybe there is something else broken inside the drone?
Pls Help
