DJI-Jamie
Flight distance : 112405 ft
X4IFEzcj7gkM Posted at 2017-4-14 16:09
I've had the unit since October. Never dropped. I actually have 2 P-4s and the remotes are identical gap wise
One thing that concerns me is while doing the calibration, with the sticks centered and no input from me, the left stick will drift down, then go back to zero.
It sounds like something may be loose. If you're referring to October 2016, I wouldn't recommend taking it apart to fix it yourself. Before resorting to sending it in to DJI for service, try the following button combinations:
Reset the RC:
* Turn on the controller, and the aircraft should be off.
* Press C1, C2, and shutter on the controller then turn the controller off.
* Turn on both the aircraft and the controller and link the remote.
I would recommend manually relinking the RC to the craft so that everything is communicating properly:
* Turn on both the aircraft and the controller.
* Press C1, C2, and the record button on the controller, then the controller will beep like D-DD. This may take a few seconds of holding it.
*While holding the buttons, press the wheel on the right side of the controller and then the first light of the controller will become blue and it will constantly beep DDDD.
* Use a pen to click the linking button on the aircraft and hold for 3-5 seconds, and then take the pen off the aircraft and wait, it will be linked soon.
Let me know how it went.
