9245
Flight distance : 69455 ft
This is a known issue, as has been stated. There are two fixes: Fix it in post production with warp stabilizer, or something similar, or manually lock the gimbal. If you lock the gimbal it will fix the problem but you will get to listen to the Osmo beeping at you the whole time. Not all post production software has a warp stabilizer and even if you do, you will crop the image some. |
