Xman1
Try the video with sharpness set at +1 and you problems will be solved. Never use a setting of 0 or -1 on sharpness. When you use 0 or -1, some onboard softness process kicks in and turns your bushes to mush, especially in high contrast areas.
In addition, do not shoot at over 30 FPS.
As for your card, it is way fast and faster than what the system can use. In testing, you are not going to get over 55 Mbps and the card you have can handle that bitrate several times over.
