Kneepuck
Flight distance : 275105 ft
Lukenc Posted at 2017-4-17 07:46
What about hardware? If I purchase the HDMI output module, I assume that I can hook up an external monitor via the HDMI port. Can I still have a Iphone or android device on the controller so the operator can also see what the drone is seeing? How does the Controller communicate to the viewing device - WiFi, BT, or cable?)
Another question - Has anyone tried using an Android device for the Controller screen and then using the HDMI output on the Android device to drive an external monitor? Would you need the HDMI Module in that case (if it works). Ideally, you could drive something wirelessly (e.g. Chromecast), but I haven't found posts where someone did it...
Yes, I have done both. Works fine. Even if you use the hdmi port for goggles. Using chromecast or similar introduces a bit of latency, so is less desireable. |
