rydfree41
Flight distance : 153268 ft
You may have to downgrade the FW on the controller to that of the Mavic , re-boot and try again .
When attempting the update again try the following .
I turn the Mavic on then the controller and let them connect as usual then connect the controller to the computer with assistant 2 . Assistant will show the controller icon only but will update controller ,Mavic and battery at the same time . The Mavic itself may have to be in another room and the controller and PC closest to your WiFi router for it to stay connected for the duration of the update . For some reason the Mavic will disrupt the Wifi signal and if the connection ever blinks even for a moment it will fail . |
