Bootspike
Flight distance : 109281 ft
Yes Eric, the angle is very low, but the antennas were vertical. That is, set at 45 degrees with the controller at 45 degrees. The video link started to break up which is unfortunately fairly common and the the message appeared then appeared that the link was lost.
As I mentioned, the quality of the video was excellent which is why I am using this unit. In this instance, we were following a bush track from a persons perspective and intending to lift over the water of a farm dam to take in the sunset at max altitude. This flexibility is great, but I think this particular unit may have a glitch. The flight time for it is a little over 5 hours and I admit, some learning is still happening. Some further checking is to be done. |
