New Battery
830 14 2017-4-17
fans17a7caf3
Flight distance : 254190 ft
Can anyone advise me how to update the firmware on a second battery that i just bought (new) thanks
2017-4-17
RedHotPoker
Flight distance : 165105 ft
Put the firmware on the sd card, and place it in the drone, then insert the battery and turn it on.
Leave your RC off.  ;-)
The update takes less than five minutes to install firmware. Watch the LEDs change pattern, while the update happens.
Congrats on the second battery.... The more the merrier the pilot. Ha
RedHotPoker
2017-4-17
fans17a7caf3
thanks for advice. firmware already on the sd card when i updadated the drone after purchase last week. when i bought the second battery and carried out the steps that you have mentioned bat still get a message saying update battery firmware. would appreciat any further advice thanks
2017-4-17
ibuyufo
Flight distance : 819098 ft
Just insert the battery and turn the phantom on.  The remote will tell you there's an update.  Slide to update.  No need to put the firmware in the SD card.
2017-4-17
fans17a7caf3
Hi thanks for your reply  but firmware is up to date. What happens is I turne on the controller turn on the drone connect the app  on the screen says firmware update when I tap on it it says update battery firmware tap on that it says go to DJI tutorial to learn how to update firmware thanks
2017-4-17
solentlife
Flight distance : 1087530 ft
Latvia
ibuyufo Posted at 2017-4-17 08:22
If the FW is not on the card ... where is the battery going to get it from ?
But if its not on the card ... then you need remote and tablet to be on ... and go through the update process ... using download ...
Nigel
2017-4-17
DJI-Jamie
Flight distance : 112405 ft
fans17a7caf3 Posted at 2017-4-17 08:14
Post #4 hit the nail on the head. I would reinstall the app, though, just to see whether or not the request to update persists. If it does, ibuyufo's advice should work.
2017-4-17
fans17a7caf3
hi i would like to thank everyone for taking the time to reply. I used a brand new sd card along with the new battery switched on the controller turned on the drone started the app it informed me to update the firmware when i completed the update it updated the battery as well so thanks again everyone
2017-4-18
solentlife
Latvia
Just to humour me .... have a look at the SD Card ... does it have two files on it in the root ... one ending in .bin    and other ending with .txt .... ?
DJI Jamie - I have to say although is DJI Team has avoided the card part ... because the reason it is advisable to leave the FW update file on the SD card is precisely for this reason ... to update any new battery that comes along automatically. If you have latest FW on the card and you have an old FW battery ... when you insert into the AC and switch on ... in those few first seconds of initialisation - the two FW's are compared and Battery updated if necessary.
I may wrong - but evidence so far observed for my own gear indicates I may be correct.
Nigel
2017-4-18
fans17a7caf3
hi looked at the two sd cards originall card and the one i purchased and your right the two cards are the same one .txt file and one .bin file
2017-4-18
solentlife
Latvia
Exactly .....
Thanks. The bin file is the FW and holds all the relevant code for battery, controller and AC FW's ................
The txt file if you open it - is a log of every start up since file created ...
Nigel
2017-4-18
DJI-Jamie
fans17a7caf3 Posted at 2017-4-18 02:39
Good to hear you were able to get sorted.
2017-4-18
DJI-Jamie
solentlife Posted at 2017-4-18 04:32
I'm having a little difficulty understanding the question. Are you asking whether or not it's ok to leave the .bin file on the SD card so that it can update the extra batteries on its own when needed?
2017-4-18
solentlife
Latvia
Jamie - my post to OP to look at the SD card after updating the battery - I knew the bin and text file would be there. To support the claim as I and others made that the bin file updates the battery.
Sorry to say this but you as a DJI team member made a fundamental error in your post earlier ignoring this fact. Supporting another's post where he said the SD card didn't matter.
The bin file on the SD card is checked against the AC FW each time we power up ... this includes battery FW. If SD card is found to have later FW - then auto update of battery occurrs in those few start up seconds. Jamie - you should know this.
Nigel
2017-4-18
RedHotPoker
Happy here, to hear, that the battery in question has been updated... ;-)
Yes, the bin file on the micro sd card will update any newer batteries that have older firmware...
DJI-Jamie?? How have you been? ;-)
RedHotPoker
2017-4-19
