Ex Machina
Flight distance : 1806362 ft
NoSale Posted at 2017-4-18 13:30
My understanding is that while data can be shared via hotspot, the iPhone GPS isn't passed to the device; so no live maps/active tracking. Now maybe I'm wrong, but I was under the impression that an iPad Mini 4 w/data does have its own GPS. Is this wrong?
Frankly, I'm still fine with using my iPhone 6, but think the day may come where I want a bigger display and would like to avoid getting calls midflight. It would be useful if Verizon had a feature to send directly to voice mail, but haven't found that yet.
Mapping and anything else that requires data will work just fine while tethered, remember the map is reporting on the Mavic's flightpath, not your phone's location. I'm pretty sure whitelisting also uses the GPS in the Mavic, so that should work as well, but maybe someone else can confirm.
Active Tracking doesn't use GPS, you're thinking about Follow Me, which I'm guessing won't work very well if at all, but then it doesn't work really well or at all for lots of us, anyway (the feature seems to require more satellites/signal than the Mavic does to actually fly). Probably add setting the homepoint as your current location as well to that list that would require a cellular-capable iPad. |
