Mavic pro update fail
1290 2 2017-4-18
fans790f9362
Hi guys, I just wanted to let you know of my experience of the latest update.
The drone and controller worked fine - after a short flight I noted that there was a update required on the app
I downloaded the software on the app and it started to update then it stopped working - saying the update failed
Downloaded the DJI assistant 2 - then when through the process of downgrading the software on both the drone and controller and updated the software version by version
fired up the drone and the gimbal started to track left and right, the drone flew as expected and but the camera function didn't work at all
So did the process again - but this time the forward object avoidance system was not working.
Took it to my local drone shop thinking they may have software that could rectify the issue - It will be a 2 - 4 week turn around before the drone is back because it had to be sent back to DJI Melbourne
Whilst in the drone shop the technician was talking multiple from other customers having the same experience.
No crashes on the drone - drone worked perfectly prior to the latest update.
perhaps you should look at this before updating your firmware - if its not broken don't fix it
cheers and happy flying
2017-4-18
Sorry to hear about the issue with DJI product.
Have you sent in the aircraft?  Have you tried to do the VPS calibration via DJI assistant?
2017-4-19
Alpha_te
Yeah I've done everything that I am able to do - it's been sent back for a full software reinstall at the factory level I am really disappointed that it will take 2-4 weeks considering that it was a firmware fault
2017-4-20
