theGrindLab.com
Flight distance : 1375846 ft
Eric13 Posted at 2017-4-19 10:45
Yes - since the gimbal is always in an active/motor controlled state when AC is switched on.
Even if it is visually calm.
High end gimbals are getting 2000 or more sensor data/motor correction inputs per second.
I have 3 other, larger, more expensive brush-less 3-axis gimbals (when they first came out, these gimbals alone cost almost as much as the P4P) that do not behave like this in lock mode. Of course, lock mode may be handled differently on these other devices. Perhaps the P4P "suffers" from this due to its gimbal's tech/quality level? |
