Nigel_
Flight distance : 388642 ft
I was thinking this the other day when watching a P4P being landed by a stranger I encountered on a walk.
It could be annoying if done wrong, but I think it would be very good if it did a "beep beep .... beep beep .... beep beep." if you have flown out of range of the ultrasonic sensors (higher than 15m) and then drop back into range of the ultrasonic sensors, at the point when the ultrasonic sensors first detect the ground (between 10 and 15 meters). It would then also do it if you flew too close to the top of a tree and the ultrasonic sensors detected the tree, or building etc.
Only problem I see with this is that there seem to be quite a few logs being posted where the ultrasonic sensors falsely detect the ground on occasion while they are up at 100 meters, that would become very annoying, but it would also tell you that there was a fault before the aircraft decides to turn it's motors off and drop out of the sky as it passes the 15m point! |
