Donnie *
Flight distance : 3636782 ft
As Phantom Paul says , check that mesh between the Camera Gimbal and the Vibration board, also follow the 2 flat ribbon cables from the Vibration board to the AC, sometimes they can get "crimped " or pull out of the socket and cause problem , examine this closely , push the vibration board down so you can see the flat ribbon cable between the aircraft and the Vibration board . , I have heard of this before, more than likely this is where your problem lies . Make sure also that you line up the back slot guide of the X5 BEFORE getting the round gimbal into the vibration board , once the back of the camera is in the slot the camera should just ease up and then you can lock it in place .
During the crash I bet the flat ribbon cables were pulled out or broke as well. Sometimes there is more damage than we just see , this is a simple fix and you can order new flat ribbon calbes as well.
good luck , let us know what you find
donnie
