Punchbuggy
Flight distance : 483166 ft
DJI's stock response is valid - perform an IMU calibration on a perfectly flat surface, then do a gimbal calibration. That sets the IMU sensors and the gimbal mechanism to a clean baseline setting which it'll make decisions based on.
If the horizon still gets out of whack, try hovering, do a 360 degree yaw, and wait for a few seconds - this helps it to realise that the gimbal may not be level and correct it again. The alternative it to adjust the off-set manually on-the-fly - you can do that using the RC and C2/wheel sequence, or the 'Adjust Gimbal Roll' feature in the DJI GO app. I use the last, after turning gridlines on so I have a guide to show me when the camera is level (and when it's not).
Otherwise, I note the horizon levels are better on my P4P after the most recent firmware update (released last week). Others haven't reported this though... |
